Results 1 to 15 of 15
Thread: Swimming Pool Heat Pump
10-09-2010, 08:00 PM #1
Hi all,
Can anybody recommend a make of heat pump, for a swimming pool installation ?
it needs to be about 30kw
11-09-2010, 03:23 AM #2
Re: Swimming Pool Heat Pump
Mitsi Electric do a city multi, and also Daikin. I'm sure there are a few more.
Have you got some more specific information?
11-09-2010, 07:52 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
11-09-2010, 08:08 AM #4
Well, I assume elex is looking for a hot water heatpump, right?
Mitsi have a heatexchanger that goes with their city multi system( up to 25kw) and Daikin have their Altherma system.
Or am I on the wrong track here?
11-09-2010, 08:47 AM #5
Must be an endless amount of Chinese wannabe heat-pumps available.
11-09-2010, 09:08 AM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
11-09-2010, 09:17 AM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
11-09-2010, 06:34 PM #8
We are a UK repair agent for Nirvana a Canadian HP manufacturer. Pretty good units and the factory is always ready to assist and cover any warranty no questions asked.
http://www.ambientcontrol.co.uk/content.cfm?cID=201
12-09-2010, 12:16 AM #9
12-09-2010, 08:09 AM #10
The Altherma nor the Mitsubishi can't do this job because they don't have a titanium exchanger. Within a 1 year, the heat exchanger will leak.
12-09-2010, 08:43 AM #11
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
12-09-2010, 10:18 AM #12
me neither
13-09-2010, 09:39 PM #13
I didn't see if the heat pump was for indoor or outdoor application.
Heat pumps for indoor swimming pools are designed to handle the ventilation of the pool hall and to maintain a suitable temperature and humidity and air quality. In the process of dehumidification the recovered heat is returned to the pool water or air as required. More sophisticated units also have an air cooling mode where the heat would be rejected to ambient when the pool water temperature is satisfied.
Outdoor pools usually are heated with an air source heat pump, some can operate in ambients as low as -10C/ -15C
In all cases the pool water heat exchanger needs to be designed with consideration of the pool chemistry. There is a misconception that pool water with chlorine causes corrosion issues. However, this is not necessarily the case. If the water chemistry is maintained correctly then there should be no problem with corrosion of cupro & copper materials. Usually the main culprit for corriossion issues with pool equipment occurs when the Ph value falls too low, below 7.0 or, there are too many people using the pool without showering, kids cause problems also with organic material being left in the pool, and the free chlorine levels drop below set values. Then Chloramines are created as a byproduct of chlorine and this is very corrosive.Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
14-09-2010, 05:25 AM #14
^ Do not p in the pool.
14-09-2010, 08:16 PM #15
Many thanks for your replies
Addition of a heat pump to solar heating system
By rt29781 in forum Heat PumpsReplies: 24Last Post: 23-01-2010, 08:46 AM -
Alto swimming pool heat pump
By A2E Services in forum Trouble ShootingReplies: 7Last Post: 16-09-2009, 07:45 PM -
ned help for calorex swimming heat pump
By rkmoorthy in forum Technical DiscussionsReplies: 3Last Post: 07-12-2008, 11:54 PM -
frostles heat pump
By Andy AC in forum The Trail of TearsReplies: 8Last Post: 26-08-2007, 04:02 PM
