Results 1 to 9 of 9
    May 2006
    Isle of Wight, Uk
    42
    424
    15
    swimming pool heat pump
    Went to look at a calorex heat pump today, not working since so called swimming pool expert had paid a visit last week and dosed the pool with neat chemicals. Home owner told us what he had done and took us round to the pool to show us the damage to the pool liner caused by the chemical. Also on the surface there was an oily scum. I went into the pool shed took the heat pump apart, pricked the suction schrader with a screwdriver and out squirted pool water The chemical ate through the heat exchanger and deposited refrigerant gas and oil throughout the pool. The homeowners kids came out a funny colour too but after a good shower, they seemed to be alright and so far, no ill effects .This incompetence of the pool man has wrecked the pool liner, heat pump,filter etc. etc. Home owner not too pleased with pool man, as you could imagine, its going to cost thousands to put right. I'm also a bit cheesed off as it was only a few months ago since we struggled like hell to replace the heat exchanger and get the thing working properly
    Andy
    70
    10,650
    52
    Re: swimming pool heat pump
    Brings to mind the old adage.....
    If it ain't broke, don't fix it.
    Makes you wonder how many minutes training the pool man was given before he was sent on the road.
    You can see the job advert now can't you----
    Pool maintenance man wanted, no experience required, full training will be given.. and so on.
    Apr 2006
    35
    1,646
    The second I read "Also on the surface there was an oily scum" I groaned, and instantly said to my self "Ruptured Hx"
    I'd have a myocardial embolism at that point and the pool company would be sharing it!
    Is the pool company at least going to make good on their damage?
    Sep 2005
    uk
    48
    504
    15
    I've done this one before, but, a few years ago i was called to a pair of chillers on a bulk tank that had an acidic 24 hour cleaner added and left for three months. same dance, very little left of evaporators and nice acid water right round inside of system.
    now that did cost a few thousand to put right !!
    Takes a licking, keeps on ticking.
    Apr 2007
    none
    10
    Quote Originally Posted by Andy AC View Post
    Andy
    Andy,
    You'll NEVER find a home owner that will admit to not keeping an close eye on both the PH and chemical levels in his/her pool. You can destroy even a cupronickel hxer in less than a week with a bad PH or out of balance pool.
    I've seen 316L Shed. 80 fittings wrotted out in 6 months with 'supposedly' well monitored pool water. The ocean side water fittings were in relatively new shape
    NC
    264
    12
    http://www.csgnetwork.com/poolchemcalc.html
    Give them that website to help them with how to figure how much chemicals to add.
    http://www.rhtubs.com/langlier.htm
    this calculator will tell them if their pool water is corrosive or scale forming. You can find same type calculators in C if that is what you need just google it.
    NC
    264
    12
    http://www.ccthd.org/articles/enviro...poolmanual.htm
    This is a how to on pool operation.
    Now you can charge them the money for getting a pool person out to check chemicals/add.
    May 2006
    Isle of Wight, Uk
    42
    424
    15
    Cheers for the info Bigjon
    Andy
    NC
    264
    12
    No problem I know it's in F and american units but it still may help.
    here's a hint also your chemicals can be perfect at 70F but at 20F The pool can be extremely corrosive with the only change being the pool temp. Most homeowners don't know what they are getting into whenever they decide to buy a pool. And the Pool guy that showed up must have been a fly by night company. No one in their right mind would add enough chemicals to destroy a pool it's liner and heat pump.
    If I had to take a guess he poured straight chlorine or put tabs in the skimmers. This is the best way to corrode your pump impeller and any other type of metal this super chlorinated liquid goes through. If you go into the pump room and everything has rust on it. walk away as fast as you can. Thats what happens when ammonia and to low of a level of chlorine are present in the pool. It cause chlorine gas (exactly like when you mix chlorox and ammonia!!!!!!!!!)
    (WARNING DO NOT TRY MIXING THOSE TWO CHEMICAL TOGETHER!!!!!!!!! for anyone with a wild hair.)
  1. frostles heat pump
  2. ALTO swimming pool heat pumps
    By Andy W in forum Heat Pumps
    Last Post: 28-11-2007, 02:05 PM
  3. Heatstar swimming pool heat pump
    By Latte in forum Trouble Shooting
    Last Post: 28-06-2007, 06:15 PM
  4. pool heat pump
    By coolflow in forum Heat Pumps
    Last Post: 12-05-2006, 07:19 AM
  5. New Subject - Swimming Pool Heat Pumps
    By LanzaCarlos in forum Trouble Shooting
    Last Post: 09-02-2006, 01:58 PM
