Results 1 to 13 of 13
Thread: Problem with cold room
Threaded View
15-02-2012, 12:52 PM #2
Re: Problem with cold room
Is the compressor getting power but not starting?
Many air con compressors are not designed for starting under load as is the case with a expansion valve, so assuming the start capacitor is ok now, the addition of a start relay and start cap should help with starting the compressor when its used outside its design conditions.Mostly found in Oxfordshire, UK :)
