    Oct 2008
    newbury
    1,444
    ITouch min/max temps
    I'm struggling here a bit
    Is there a simple way to adjust the all the air con units on the Itouch for the mix (18) max ( currently 24 to 26) temp range lock for the simplified controllers in one easy process?
    Jun 2009
    North East England
    712
    Re: ITouch min/max temps
    select all in the home screen,
    then go to prop[erties change from monitor to set then change your settings then switch back to set you can find the manual here http://extranet.daikin.co.uk/login.htm
    Oct 2008
    newbury
    1,444
    Quote Originally Posted by james10 View Post
    James
    I have the manual but it's very confusing :-(
    Jun 2009
    North East England
    712
    James
    I know i went on the course for the itouch and was told the best way to learn them is to chuck the book and play with it (it being the controller)
    70
    4,702
    47
    Yea, We have Training courses of the same quality.
    With the same outcome.
    Oct 2008
    newbury
    1,444
    Does anyone actually know how to do this???
    Sep 2009
    Scotland
    374
    Re: I Touch min/max temps
    Hi Mr Barlett,....How's tricks?
    I think your question is far more complex than the I controller What do you mean mix (18) max???
    The only way to limit the set point adjustment range is to do 1 unit at a time by:
    Select ZONE/GROUP
    highlight unit
    SETTINGS
    SETPOINT RANGE
    Tick enable then input required min/max temps for cooling & heating.
    Oct 2008
    newbury
    1,444
    Quote Originally Posted by VRVIII View Post
    Select ZONE/GROUP
    highlight unit
    SETTINGS
    SETPOINT RANGE
    Good to see you back on line.
    This is going to be a long day as we've 80 bedrooms to change
    I can't believe there isn't an 'all' facility for this as it's a basic function....
    Either way thanks as ever
  1. Compressor oil temps
    By Superfridge in forum Industrial Compressors
    Last Post: 17-11-2009, 08:35 PM
  2. Daikin Itouch & Firefox
    By email_dd in forum Air Conditioning
    Last Post: 23-07-2008, 11:31 PM
  3. OPen grab and go case wierd temps
    By kengineering in forum Technical Discussions
    Last Post: 01-03-2008, 12:21 PM
  4. Extra Horsepower From Cooling Intake Temps
    By BigJon3475 in forum Technical Speculations
    Last Post: 12-07-2007, 01:37 AM
  5. R410A split min and max line temps
    By smileypete in forum Domestic
    Last Post: 17-11-2005, 10:38 PM
