Thread: MTA air drier
12-05-2010, 05:24 PM #1
MTA air drier
I am looking for the manual of Marco polo air drier model 5MP1600 and controller parameter's list.
Controller is Dixell IC121C.
Thank you guys.
12-05-2010, 07:40 PM #2
Re: MTA air drier
Can't find an IC121 but found an XT 121, same thing??
http://www.dixell.com/linea58/downlo...-121C-D_GB.pdf
or try Dixell download site?
http://www.dixell.com/home/eng/
(You may need to register)Brian - Newton Abbot, Devon, UK
12-05-2010, 08:04 PM #3
Re: MTA air drier
Thanks brian,
The controller is OEM, special parametrs for MTA.
I could not find the way to change them.
12-05-2010, 08:07 PM #4
12-05-2010, 08:13 PM #5
Re: MTA air drier
Apparently, Dixell is connected somehow to MTA, all the controllers have different functions.
If I cant find the papers I will put a different controller with a timer for the condensed water.
It only means to rewire the control board.
13-05-2010, 07:29 PM #6
Re: MTA air drier
I installed a MTA drier earlier this year and I handed the manual into my office, if I can retrieve it I`ll email you a copy.
If you do fit a replacement controller you can always fit a timed solenoid condensate drain instead having to find a controller to enable the use of the original drain.
Regards,
Glenn
13-05-2010, 07:57 PM #7
Re: MTA air drier
Thanks very much.
I will leave you my email in PM.
14-05-2010, 10:31 PM #8
Re: MTA air drier
pass codes 4, 32, 69?
In the words of David Byrne, Well...How did I get here?
Which way up should the dessecant drier go?
By r134junkie in forum FundamentalsReplies: 8Last Post: 23-11-2009, 10:05 PM -
burn out drier
By mcunliffe4 in forum CommercialReplies: 1Last Post: 16-09-2009, 11:04 PM -
suction line drier.
By Joeheath in forum Air ConditioningReplies: 5Last Post: 10-04-2008, 08:59 PM -
Shelf life of an uncapped dessicant drier.
By eberg in forum Air ConditioningReplies: 2Last Post: 22-08-2001, 01:22 PM -
Drier Position
By subzero*psia in forum CommercialReplies: 8Last Post: 23-07-2001, 10:28 PM
