Results 1 to 10 of 10
    May 2009
    china
    Does anyone has reference books for coil circuiting?
    Does anyone has some reference books for coil circuiting design?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Does anyone has reference books for coil circuiting?
    Try REFPROP software. There is a specific part of the program dedicated to coil design.
    May 2009
    china
    Quote Originally Posted by NoNickName View Post
    REFPROP is for property of refrigerant. Do you mean NIST's evap-cond? I want some papers more detailed, I tried this software, but it shows that the more circuit you set, the more capcacity you get.
    From this point, I'm not sure about it.
    Mar 2006
    Merate (LC) - Italy
    2,549
    yeah, sorry, my bad. The more circuit you set, the longer the equivalent circuit, the more capacity and the higher pressure drop across of it.
    Mar 2009
    KZN, South Africa
    64
    2,212
    If you are serious about designing, or rating evaporators, you can purchase the DXC coil design program from Technisolve.
    http://www.coolit.co.za
    You can download a trial sample of the program & test out what you want to do. You will be able to see the effect of increased number of coil circuits on system performance.
    May 2009
    china
    Quote Originally Posted by desA View Post
    I ever use that software, it's calculation too ideal. I think when you get the surface aera of a coil, then the most important thing is to circuit it.
    I have a hard copy of carrier's handbook, on its reference books, there were an artical calls "Best practice coil design guide" by eric nash.
    It has information about how to circuit a coil, some idear include: put the inlet and outlet pipe of each circuits as far as possible and so on.
    does anyone has that artical?
    Aug 2005
    5,302
    I've never seen a book or article on this subject, although there should be one. Most of this information is at the evaporator manufacturer's. Coil circuiting is an interesting subject because you have so many different liquid feed methods, such as gravity flooded, liquid overfeed, and direct expansion.
    Jan 2010
    Australia
    Use this keyword "Scribd". It is an online book library. Look it up at google
    Mar 2009
    KZN, South Africa
    64
    2,212
    ^ You'll also need to provide the search words used, on Scribd.
    I have searched it a number of times on this very issue, but there seems to not be much available on coil-circuiting...
    Jun 2007
    South Africa
    80
    I did a quick search and did not find anything on google.
    I do agree - interesting subject.
  1. books needed
    By rich74310 in forum Refrigeration Books
    Last Post: 15-06-2009, 07:10 PM
  2. Books for Ammonia Design
    By lana in forum Refrigeration Books
    Last Post: 28-10-2005, 02:11 PM
