Results 1 to 50 of 896
Thread: AWHP superheat & sub-cooling
Threaded View
07-08-2009, 05:56 AM #11
Re: AWHP superheat & sub-cooling
Revised plan of action:
1. Modify partition separating condenser from compressor.
2. Properly insulate condenser & partition walls.
3. Test system response to these changes.
4. Re-position filter drier to vertical orientation.
5. Test system response to this change.
6. Install water regulating valve.
7. Test system response to this change.
8. Adjust WRV & iterate adjustment/testing.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
9 superheat & subcooling scenarios
By nike123 in forum FundamentalsReplies: 39Last Post: 19-07-2011, 03:16 AM -
Superheat and Subcooling
Low superheat and sucooling
By jayaeros in forum Trouble ShootingReplies: 23Last Post: 05-07-2009, 06:21 AM -
By Air duster in forum FundamentalsReplies: 10Last Post: 02-04-2008, 08:39 AM
