Results 1 to 2 of 2
    Savannah Tom's Avatar
    Savannah Tom Guest
    Cool Matching Compressor with the coil.
    A friend told me his 4 ton condenser (compressor) for his residential A/C unit died. His brother told him he would give him (free) a condenser unit but he had no coil to match it. I suggested he replace the coil to match the condenser as common practise but his brother said it wasn't necessary.
    Would there be much of a problem installing a 5 ton condenser unit with a 4 ton coil?
    Thanks for any assistance
    Moscow
    40
    82
    Re: Matching Compressor with the coil.
    As I understand, you want to replace your 4 ton coil and mount 5 ton coil.You will have bigger superheat in this case. If you want to stay in the same conditions you should have an invertor fan in your condenser unit.
  1. Efficiency of compressor assisted HRV
    By montreal in forum Heat Pumps
    Last Post: 27-08-2007, 08:51 PM
  2. Dont be shy, advice needed.
    By Sledge in forum Air Conditioning
    Last Post: 27-06-2007, 03:09 PM
  3. Coil in Coil condensors and subcooling.
    By Bernoulli in forum Industrial
    Last Post: 16-12-2006, 08:21 AM
  4. Burst Coil
    By frank in forum Air Conditioning
    Last Post: 20-02-2005, 06:28 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
