Results 1 to 11 of 11
    Feb 2023
    Australia
    2
    York Air Conditioning YCS046R4D
    Hi Guys,
    First time here so be nice.
    I need the Kilo watt rating of the York commercial system.
    Model - YCS046R4D
    Thank you
    ireland
    1,450
    41
    Re: York Air Conditioning YCS046R4D
    Should be on the nameplate on outdoor unit? Or contact local York dealer
    Feb 2023
    Australia
    2
    Thank you for replying, yeah nothing on the name plate that’s why I’m here.
    Tried 1000 different numbers for York but they never answer
    3,362
    Oct 2001
    Nottingham UK
    5,668
    Can't find a YCS
    Y = York
    C = Chiller
    A = Air Cooled
    S = Screw
    046 = 46kW
    https://www.google.com/url?sa=t&sour...fvY9r7IV7hoiSM
    https://www.manualslib.com/brand/york/chiller.html pictures of the different models.
    Name plate nomenclature https://www.manualslib.com/manual/23...page=23#manual
    3,362
    Just add, no one answers phone, got to email them.
    Way of the world now unfortunately.
    Oct 2001
    Nottingham UK
    5,668
    Somerset
    69
    4,706
    This may help a little further?
    Hopefully?
    https://www.mediafire.com/file/l18k3...r/YRM.pdf/file
    Please note- YRM = Packaged Unit.
    YCS = Condensing Unit.
    The logical breakdown of the unit code explained within. Would suggest your Unit is a 46KWR sized unit!
    Good luck Grizzly
    Somerset
    69
    4,706
    Rob. It would nice to update us as to whether what was supplied was of any use to you?
    Mar 2023
    9
    The York YCS046R4D is an air conditioning unit manufactured by York, a company specializing in HVAC (Heating, Ventilation, and Air Conditioning) systems. Here are some general details about the York YCS046R4D:
    Cooling Capacity: The "YCS046R4D" model number suggests that it is a 4-ton unit. The cooling capacity of an air conditioner is typically measured in British Thermal Units (BTUs) per hour, and a 4-ton unit generally has a cooling capacity of around 48,000 BTUs per hour.
    Energy Efficiency: The energy efficiency of the York YCS046R4D can vary based on the specific model and configuration. It is advisable to refer to the unit's technical specifications or consult with a professional HVAC technician to determine its energy efficiency rating, Seasonal Energy Efficiency Ratio (SEER), or Energy Efficiency Ratio (EER).
    Features: The specific features of the York YCS046R4D may depend on the model and series. Common features in York air conditioning units include adjustable fan speeds, programmable thermostats, humidity control, and compatibility with zoning systems.
    Professional Installation: Air conditioning units, including the York YCS046R4D, typically require professional installation. It is important to consult with a licensed HVAC contractor or technician to ensure proper sizing, installation, and maintenance of the unit to optimize its performance and efficiency.
    It's worth noting that specific details, specifications, and availability of the York YCS046R4D may vary, as manufacturers often update their product lines over time. For the most accurate and up-to-date information about this particular model, it is recommended to refer to the manufacturer's official documentation, contact a local York dealer, or visit the official York website.
    Jul 2023
    1
    Professional installation is key to ensuring optimal performance and efficiency when it comes to HVAC systems. Consulting with licensed hvac contractors hamilton would be a great idea to get expert advice and assistance with the installation process.
    Remember, product specifications and features can sometimes change over time, so checking the manufacturer's official documentation or reaching out to a local dealer for the most up-to-date information is a smart move.
