    Apr 2013
    10
    cold room mains cable and isolator sizing
    Im looking to give a quotation for a cold room but abit unsure how to calculate the correct size mains cable required to ensure the job is safe. I know the system needs a 20A breaker but not sure what size cable would be safest to use...also is the ampage of the rotary isolator worked out on the breaker size or the cable size?
    Feb 2009
    telford
    2,090
    33
    Re: cold room mains cable and isolator sizing
    dont quote for electrics if you are not an electrician,get an electrician to do it.
    Oct 2008
    newbury
    1,444
    37
    Quote Originally Posted by wheats8 View Post
    If you are at this level I would take the above advice and save yourself a lawsuit or worse a potential fatality
