    May 2008
    dublin
    80
    daikin vrv2 reclaim
    I have a daikin rsey8kly1 outdoor which im changing the inverter comp on.is there a setting so i can drive all the valves in the outdoor on so i can reclaim of the gas.
    Thanks in advance
    Dec 2008
    563
    Re: daikin vrv2 reclaim
    Set the condensing unit in to service code 21 to open the valves for reclaiming and vaccing out.
    See this link http://www.refrigeration-engineer.co...ervice-mode-21
    Bedford. Now retired and trying to relax.
    Oct 2003
    5,630
    34
    Ballvalve, when was this unit installed and what's exactly the roblem with it?
    VRII or VRVIII?
    Sep 2009
    Scotland
    374
    R22 VRV doesn't have a vac/reclaim mode, use three port gauges and vac/reclaim form the three lines (liq/Dis/Suct).
Tags for this Thread
