Results 1 to 8 of 8
Thread: ITouch min/max temps
19-10-2010, 12:05 PM #1
I'm struggling here a bit
Is there a simple way to adjust the all the air con units on the Itouch for the mix (18) max ( currently 24 to 26) temp range lock for the simplified controllers in one easy process?
19-10-2010, 05:42 PM #2
Re: ITouch min/max temps
select all in the home screen,
then go to prop[erties change from monitor to set then change your settings then switch back to set you can find the manual here http://extranet.daikin.co.uk/login.htm
19-10-2010, 06:29 PM #3
19-10-2010, 07:19 PM #4
19-10-2010, 07:58 PM #5
the best way to learn them is to chuck the book and play with it (it being the controller
Yea, We have Training courses of the same quality.
With the same outcome.
20-10-2010, 03:58 PM #6
Does anyone actually know how to do this???
20-10-2010, 08:49 PM #7
Re: I Touch min/max temps
Hi Mr Barlett,....How's tricks?
I think your question is far more complex than the I controller What do you mean mix (18) max???
The only way to limit the set point adjustment range is to do 1 unit at a time by:
Select ZONE/GROUP
highlight unit
SETTINGS
SETPOINT RANGE
Tick enable then input required min/max temps for cooling & heating.
21-10-2010, 10:11 AM #8
Compressor oil temps
By Superfridge in forum Industrial CompressorsReplies: 5Last Post: 17-11-2009, 08:35 PM -
Daikin Itouch & Firefox
By email_dd in forum Air ConditioningReplies: 2Last Post: 23-07-2008, 11:31 PM -
OPen grab and go case wierd temps
By kengineering in forum Technical DiscussionsReplies: 22Last Post: 01-03-2008, 12:21 PM -
Extra Horsepower From Cooling Intake Temps
By BigJon3475 in forum Technical SpeculationsReplies: 14Last Post: 12-07-2007, 01:37 AM -
R410A split min and max line temps
By smileypete in forum DomesticReplies: 1Last Post: 17-11-2005, 10:38 PM
