Results 1 to 13 of 13
Thread: Ys (193l s3)
    Jan 2010
    South
    15
    Ys (193l s3)
    Needing a parts listing and exploded view of this compressor and also for the oil seperator. I have tried without any success to locate online and also with Baltimore.
    Any help would be greatly appreciated. Thanks!
    11,025
    Re: Ys (193l s3)
    Perhaps a little more info might help us help you.
    Manufacturer ?
    Equipment ?
    Or does Ys (193l s3)say it all ?
    Jan 2010
    South
    15
    Re: Ys (193l s3)
    Sorry for the shorthand.
    York YS DA DA S3-CLA
    COMP# YCCH193L399SYDF
    Apr 2008
    215
    Re: Ys (193l s3)
    Hi BSK60
    Are you losing the oil level in the sep due to low loads and/or short cycling ??
    Jan 2010
    South
    15
    Re: Ys (193l s3)
    Gingerair,
    Actualy the other matching unit on site has those same problems but I had a quick conversation with the maintenance man and found the cooling tower was having problems and they had the fan on manual. That explains that!!
    The unit in question has an oil leak at the main body gasket and I will have to split and replace the gasket. I've never had to split the casing and am trying to get an exploded view to get an idea of what I'm getting (volunteered) for.
    The parts list and exploded view for an S3 compressor is really just for my personal library.
    Apr 2009
    israel
    778
    Re: Ys (193l s3)
    Hi mail me gill@gosheng.co.il i have some info for these comps on air side units
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
    Oct 2009
    merida mexico
    54
    282
    15
    Re: Ys (193l s3)
    in something you can help
    Jan 2010
    South
    15
    Re: Ys (193l s3)
    Goshen, \
    your e-mail address is showing not valid, mine is bk.sherman01@gmail.com
    thanks for your help.
    Apr 2008
    215
    Re: Ys (193l s3)
    Due to the comp being on the evap they loose oil into it on start up & under low loads struggle to bring it back. There is apparently a piece that can be fitted in between the comp & evap that catches this oil & makes it easier to return to the compressor, i don't know if this is fitted as standard to more recent models.
    Would be surprised if the main body gasket was leaking, has the comp been disasembled before ? Have attended a site before that they reported the compressor was leaking oil from the main gasket & it was just the outlet from the shaft-seal that's positioned at the bottom of the comp. If a drain/catchpot isn't fitted oil ends up on the bottom of the comp & ontop of the evap...
    Jan 2010
    South
    15
    Re: Ys (193l s3)
    Gingerair,
    The body gasket I was referring to is on the oil seperator. The main body gasket has a leak and I will have to replace. I've never had to open up one before and was hoping for an exploded view to review and plan off of.
    Oct 2009
    merida mexico
    54
    282
    15
    Re: Ys (193l s3)
    sequence that is the machine? A, b, c, e or e. Keep the condenser water temperature to 88 ° f a good return for water
    Oct 2009
    merida mexico
    54
    282
    15
    Re: Ys (193l s3)
    WHERE DOES THE LEAK PART SEPARATOR? Send Me A PICTURE SO YOU CAN HELP
    Jan 2010
    South
    15
    Re: Ys (193l s3)
    Quick update,
    Well now I can say I have split an oil seperator on one of these and there really is nothing to it.
    Seal replacement went normaly.
    I appreciate the responses and hope all are doing well.
  1. Frick screw compressor 193L code S3
    By mtsivis in forum Industrial
    Last Post: 20-03-2010, 02:22 AM
