Results 1 to 26 of 26
Threaded View
24-11-2009, 07:38 PM #1
How can moisture enter a closed system?
Hello,
I know the function of the receiver/drier is to filter out moisture, but why is it needed when during the Evac process the moisture is removed?
And how can moisture enter a system even if there is a leak, because the internal pressures will always be above atmospheric.
Thanks.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Troubleshooting for Daikin Aircon CTK25FVEN
By JCTK in forum Air ConditioningReplies: 19Last Post: 05-06-2010, 07:18 PM -
Moisture in rack system.
By Chunk in forum Supermarket RefrigerationReplies: 27Last Post: 18-06-2008, 08:07 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
