    Jan 2005
    N.Ireland
    47
    177
    Need Fault Codes For Carrier Xarios 500
    Hi All
    Has anyone got the fault codes for a carrier xarios 500,
    The unit at the moment will not run and the green Led warning light is flashing at top right of controller,
    And if I press and hold set p20 comes up on the display.
    Thanks for your Help
    Chris
    Mar 2009
    Indiana, USA
    55
    75
    15
    Re: Need Fault Codes For Carrier Xarios 500
    Jan 2005
    N.Ireland
    47
    177
    Thanks for the fault codes
    Much appreciated
    Chris
    Jan 2005
    N.Ireland
    47
    177
    Hi all
    Does anyone have the p fault codes,
    The unit is running now but I am getting fault codes p01 and p20,
    The warning symbol is flashing gren and red,
    Many Thanks
    Chris
    Jan 2005
    N.Ireland
    47
    177
    Got it sorted
    chris
    juntrecy's Avatar
    juntrecy Guest
    Need your help to give me an idea regarding the malfunction code p02,
    thanks
    jun
    Nov 2009
    aus
    22
    there is no differance between AXX and a PXX, A means its a active alarm, and P means its a past alarm.
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. Daewoo Air Conditioner Fault Codes REQUEST
    By frostedflake in forum Air Conditioning
    Last Post: 13-07-2009, 03:43 AM
  3. Daikin fault codes
    By Markie in forum Air Conditioning
    Last Post: 13-01-2009, 01:58 AM
  4. standardisation of fault codes?
    By kelvin kline in forum Air Conditioning
    Last Post: 10-10-2007, 12:30 AM
  5. MHI, Sanyo & Fuijitsu Complete Fault Codes
    By aeb200 in forum Air Conditioning
    Last Post: 16-11-2005, 01:11 PM
