Thread: Dixell Xc 911m
14-04-2008, 01:18 PM #1
Dixell Xc 911m
Is Anybody Works With Dixell Xc 911m? I Need Help About Connecting Probe Input. If Anybody Have Electric Shema....but Not From Dixell, I Have It. Thanks!
14-04-2008, 11:21 PM #2
Re: Dixell Xc 911m
Hello and welcome to the forum.
What is the problem you are having with connecting the probes?
The wiring schematic clearly shows the connections.Brian - Newton Abbot, Devon, UK
15-04-2008, 10:06 AM #3
Re: Dixell Xc 911m
Yes, but when I conncet they don't show right value and occure alarm A01F. When I switch polarity then occure alarm Er0H.
15-04-2008, 12:20 PM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Dixell Xc 911m
Check your probe and configuration:
5.3.2 Condensing probe configuration
Pbc: Probe selection. Cur = 4 ÷ 20 mA probe; ntc = NTC probe.
PA04: Adjustment of read out corresponding to 4mA (present only if Pbc=Cur). input
signal, given by the suction probe (0 ÷30 bar or 0÷435 PSI or 0 ÷3000 KPA)
Warning: set a value correspondent to absolute pressure. If the transducer measures
relative pressure increase the range by 1 bar.
E.I. PP30 relative pressure transducer, range: 0÷30bar. PA04=1; PA20=31.
PA20: Adjustment of read out corresponding to 20mA input signal, given by the suction probe
(0 ÷ 40.0 bar or 0÷580 PSI or 0 ÷ 4000 KPA) SEE THE WARNING IN PA04.
CAL: Condensing probe calibration (-1.00÷1.00bar; -10.0÷10.0 °C or -20÷20°F/PSI or
-100÷100KPA)
Probe is NTC and polarity shouldn't be a issue.Last edited by nike123; 15-04-2008 at 12:23 PM.
Dixell Controller
By 4Qman in forum ElectricalReplies: 7Last Post: 18-12-2007, 12:39 AM -
Dixell Clone
By Peter_1 in forum ElectricalReplies: 3Last Post: 20-01-2006, 07:54 AM -
Dixell controllers
By eggs in forum Technical DiscussionsReplies: 6Last Post: 17-08-2005, 10:59 PM
