    Oct 2007
    Nepal
    Window Heat Pump (A/C)
    A new window A/C, (Heat Pump) has unique problem. It operates well on cooling mode but on heating mode (with reverse valve) the heating stops after a while (an hour or so), and the suction pressure equalizes to higher pressure. The heating can be resumed only after the machine is manually switched OFF and turned ON. However same cycle is repeated. I have ruled out moisture in the system, and Reversing valve winding
    Please share your experience and help diagnose the fault.
    Oct 2007
    mid-atlantic state, USA
    Re: Window Heat Pump (A/C)
    I'd look into the defrost method.
    NC
    262
    Sounds like it's not coming out of defrost.
    Oct 2001
    Nottingham UK
    5,667
    What are the ambient temperatures when you ask it to heat?
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, Frank
    Rabindra is from Nepal and Himalaya is there too....cannot be too warm there.....maybe too cold even for Extra Pale Ale.
    Best regards, Josip
    Oct 2001
    Nottingham UK
    5,667
    Always start with the basics
    Regards Josip
    Frank
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. DIY heat pump 12kW
    By kimusabi in forum Fundamentals
    Last Post: 17-10-2009, 07:50 PM
  3. frostles heat pump
  4. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  5. Domestic VRF heat pump?
    By electronicsuk in forum Heat Pumps
    Last Post: 30-10-2007, 07:53 AM
