Results 1 to 21 of 21
Thread: 2 question
30-04-2012, 09:11 PM #1
2 question
hi every one
i have 2 question
1 - how many screw i need to fit in the plate on the wall for the split type air cond. indoor unit
some people say 4 and other say 8 etc
2- during charging the air conditioner is there any need to flip up ***** cylinder or must keep it without flip
thank you
30-04-2012, 09:14 PM #2
Re: 2 question
1 - Enough screws to make sure it stays on the wall.....depends on what the wall is made of....
2 - Depends on the refrigerant being used.......Depends on the cylinder it's in......
Next questionTool's ? check ! Condom's ? check !
30-04-2012, 09:19 PM #3
Re: 2 question
ok for 1 question
in iraq we build bulding walls
from concrete.cement block.bricks
for 2nd question
r22 cylindir
30-04-2012, 09:25 PM #4
Re: 2 question
Upright for vapour withdrawal ,flip it over for liquid !(presuming you only have one valve and no dip tube)
R22 can be charged as a vapour as it is not a blend.
30-04-2012, 09:29 PM #5
Re: 2 question
thank you
what about 1 question
30-04-2012, 09:35 PM #6
Re: 2 question
As many as required !!!!
No one is going to complain about the price of a few screws.
But they will complain if the A/C unit falls off the wall and lands on their kid.
Use common sense .
Most manufacturers provide screws for mounting the plate ,so count them ,and use it as a guide line.
30-04-2012, 09:37 PM #7
Re: 2 question
thank you pal
you helped me
30-04-2012, 09:38 PM #8
Re: 2 question
No problem.
Keep it up.
30-04-2012, 09:40 PM #9
Re: 2 question
i hung a daikin 71 cassette off 6 tech screws holding 41 21 strut to a duct- then i fitted 41 41 strut with rawl bolts then droprods to transfer the load-as for the elusive question no 1- 1 fixing in the centre of the bracket to allow for exact centring- then 2 at the top corners to keep the top lip of the brcket tight to the wall, then 2 in the lower corners for where it clips onto the indoor unit- some manufacturers show on the installation instructions where they want the fixings, as long as the bracket is firmly fixed to the wall,typically the indoor only weighs around 7kg-unless its a 10kw wall mount that are upto 30kg!!-i remember getting called to an ac unit hanging off the wall- turned up and low and behold an imi cu80 was at 40deg only held on with its bottom fixings- had to re secure it whilst still piped up!
30-04-2012, 09:45 PM #10
Re: 2 question
Where's that Daikin unit???
So I can avoid walking under it.
30-04-2012, 09:52 PM #11
Re: 2 question
thank you again
the split unit mark is LG
split type ac 2 ton 24000 btu
so for these indoor plates how many screws i have to fit at least
30-04-2012, 09:52 PM #12
Re: 2 question
still fitting it-dont worry its bombproof!
did an install years ago-had 2 cassettes in a bp station- as it was just a corrugated tin cladding roof- no steelwork to fix off and was a rush job- from the drop rods off the cassette had to use standoff brackets for tray -and 4 1 1/4 pozi with washers on each corner- still up 10yr later!!but as the outdoors was mounted straight on the butyl rubber roof they moved a bit in the wind! haha
30-04-2012, 10:10 PM #13
Re: 2 question
some questions on this scare me thinking about them...
30-04-2012, 10:13 PM #14
30-04-2012, 10:26 PM #15
Re: 2 question
as a rule of thumb id fit 1 screw per 1000btu
01-05-2012, 01:31 PM #16
Re: 2 question
Umm, how many screws is that per kw...........duh
01-05-2012, 05:42 PM #17
Re: 2 question
Just put in as many as you can, there will be holes in the bracket, so just use that as a guide to how many!!
The more the better!
I can't quite understand the problem, unless your buying an exact amount of screws to do this with, in which case just buy a handfull and bung them in!
J
01-05-2012, 06:47 PM #18
Re: 2 question
OK,
True answer... 0 (zero), you don't need any screws at all...
A few years back I were asked to do an install in a "tanked" room, no penetrations through the membrane was allowed.
Pipework down the stairs and wall mounted unit glued on to wall using epoxy resin.
It stayed up for at least 5 years but I haven't been back there for a while so it might have dropped of by now.
01-05-2012, 10:28 PM #19
01-05-2012, 10:36 PM #20
02-05-2012, 09:08 PM #21
Re: 2 question
Why use screws???? http://www.google.co.uk/products/cat...ed=0CGIQ8wIwAA#
