Results 1 to 21 of 21
Thread: 2 question
    Apr 2012
    Iraq
    30
    614
    11
    2 question
    hi every one
    i have 2 question
    1 - how many screw i need to fit in the plate on the wall for the split type air cond. indoor unit
    some people say 4 and other say 8 etc
    2- during charging the air conditioner is there any need to flip up ***** cylinder or must keep it without flip
    thank you
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    1 - Enough screws to make sure it stays on the wall.....depends on what the wall is made of....
    2 - Depends on the refrigerant being used.......Depends on the cylinder it's in......
    Next question
    Tool's ? check ! Condom's ? check !
    Apr 2012
    Iraq
    30
    614
    11
    Re: 2 question
    ok for 1 question
    in iraq we build bulding walls
    from concrete.cement block.bricks
    for 2nd question
    r22 cylindir
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    Upright for vapour withdrawal ,flip it over for liquid !(presuming you only have one valve and no dip tube)
    R22 can be charged as a vapour as it is not a blend.
    Stu
    Apr 2012
    Iraq
    30
    614
    11
    Re: 2 question
    thank you
    what about 1 question
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    As many as required !!!!
    No one is going to complain about the price of a few screws.
    But they will complain if the A/C unit falls off the wall and lands on their kid.
    Use common sense .
    Most manufacturers provide screws for mounting the plate ,so count them ,and use it as a guide line.
    Stu
    Apr 2012
    Iraq
    30
    614
    11
    Re: 2 question
    thank you pal
    you helped me
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    No problem.
    Keep it up.
    Stu
    Oct 2007
    manchester
    44
    5,707
    Re: 2 question
    i hung a daikin 71 cassette off 6 tech screws holding 41 21 strut to a duct- then i fitted 41 41 strut with rawl bolts then droprods to transfer the load-as for the elusive question no 1- 1 fixing in the centre of the bracket to allow for exact centring- then 2 at the top corners to keep the top lip of the brcket tight to the wall, then 2 in the lower corners for where it clips onto the indoor unit- some manufacturers show on the installation instructions where they want the fixings, as long as the bracket is firmly fixed to the wall,typically the indoor only weighs around 7kg-unless its a 10kw wall mount that are upto 30kg!!-i remember getting called to an ac unit hanging off the wall- turned up and low and behold an imi cu80 was at 40deg only held on with its bottom fixings- had to re secure it whilst still piped up!
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    Where's that Daikin unit???
    So I can avoid walking under it.
    Stu
    Apr 2012
    Iraq
    30
    614
    11
    Re: 2 question
    thank you again
    the split unit mark is LG
    split type ac 2 ton 24000 btu
    so for these indoor plates how many screws i have to fit at least
    Oct 2007
    manchester
    44
    5,707
    Re: 2 question
    still fitting it-dont worry its bombproof!
    did an install years ago-had 2 cassettes in a bp station- as it was just a corrugated tin cladding roof- no steelwork to fix off and was a rush job- from the drop rods off the cassette had to use standoff brackets for tray -and 4 1 1/4 pozi with washers on each corner- still up 10yr later!!but as the outdoors was mounted straight on the butyl rubber roof they moved a bit in the wind! haha
    Quote Originally Posted by stufus View Post
    Stu
    Dec 2011
    Ireland
    44
    Re: 2 question
    some questions on this scare me thinking about them...
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    ​see post #6
    Quote Originally Posted by kefah View Post
    thank you again
    the split unit mark is lg
    Oct 2007
    manchester
    44
    5,707
    Re: 2 question
    as a rule of thumb id fit 1 screw per 1000btu
    Dec 2010
    Toronto, Canada
    55
    1,492
    Re: 2 question
    Umm, how many screws is that per kw...........duh
    Apr 2007
    30
    372
    Re: 2 question
    Just put in as many as you can, there will be holes in the bracket, so just use that as a guide to how many!!
    The more the better!
    I can't quite understand the problem, unless your buying an exact amount of screws to do this with, in which case just buy a handfull and bung them in!
    J
    Feb 2007
    2,477
    Re: 2 question
    OK,
    True answer... 0 (zero), you don't need any screws at all...
    A few years back I were asked to do an install in a "tanked" room, no penetrations through the membrane was allowed.
    Pipework down the stairs and wall mounted unit glued on to wall using epoxy resin.
    It stayed up for at least 5 years but I haven't been back there for a while so it might have dropped of by now.
  19. #19
    Jun 2009
    Lusk , Dublin
    1,120
    Re: 2 question
    Either that or health and safety copped it.
    Stu
    Quote Originally Posted by The Viking View Post
    OK,
  20. #20
    Oct 2007
    manchester
    44
    5,707
    Re: 2 question
    thats where overtime comes in handy-wait till they bugger off home and nail it to the wall and get the indoor clipped on- them mitsi m series and fujitsu's are a bugger to get off the wall plate!! haha
    OK,
  21. #21
    Oct 2001
    Nottingham UK
    5,128
    42
    Re: 2 question
    I'm back on the Pale
