Thread: Annie A2-12
17-06-2007, 12:48 PM #1
Annie A2-12
Hello guys, I have recently obtained an annie a2-12 compressor tester. Upon reading the instruction manual, I've found out that is the 60Hz only version - a bit disappointing. My question is can I still use it for starting compressors?, as it will be fed with 240v 50Hz. I guess that the other functions wouldn't be accurate because of the frequency change as it is set up for 60Hz, but I only ever use it for starting.
Any thoughts appreciated
Andy
27-06-2007, 11:37 AM #2
Re: Annie A2-12
Can,t see why you would not be able to use it..
The start bits are only switches and capacitors.
28-06-2007, 09:32 PM #3
30-06-2007, 01:10 AM #4
Re: Annie A2-12
Andy,
If a 60Hz unit, will it not be designed / rated for 120v?
This will mean caps (and transformer?) are wrong voltage.
I havent used one of these, so not sure if a transformer is present....somewhere there was a circuit on a previous thread.
Adrian
30-06-2007, 06:51 PM #5
Re: Annie A2-12
You can feed it on 110 or 220v power @ 60hz, I still haven't got around to giving it a go but I will let you know what happens.
Andy
13-07-2007, 08:00 PM #6
Re: Annie A2-12
Dear Peter_1
I am very sorry for the comments I made. By an oversight I misunderstood it. Therefore I would kindly request you to delete the above post of mine.
Suny
04-08-2007, 02:07 PM #7
Re: Annie A2-12
Why not write or call Thermal Engineering about your question.
04-08-2007, 04:48 PM #8
Re: Annie A2-12
I have the same unit which my sister sent me from the USA. I have used it as is to start and reverse 240/50hz compressors no prolbem.
If no sure get an old scrap compressor from a dump site and test.
Annie A-12 hermetic compr tester
By Peter_1 in forum ElectricalReplies: 27Last Post: 30-04-2010, 02:50 PM -
Annie A-3
By rdf2001 in forum Tools and CalculatorsReplies: 1Last Post: 04-06-2007, 10:47 PM -
Annie model A-12 analyzer
By chiller563 in forum Tools and CalculatorsReplies: 1Last Post: 17-11-2005, 07:44 PM -
Annie A-12 repair
By 2002kahuna in forum ElectricalReplies: 0Last Post: 21-07-2005, 04:10 PM -
Good old annie
By Cary in forum Tools and CalculatorsReplies: 7Last Post: 27-03-2005, 10:25 PM
