25-01-2017, 06:05 AM #1
delta t issue chilled water system
need expert advise as i am facing issues with delta T attained in one of the site to which FM services are given
District cooling supplies chilled water with 6 degree differential(supply 4.5 and return:11 degree Celsius)
In my load side we are able to get approx 4 degree delta T only
Supply been on a average of 7.5 and return 11 degree
When referred O&M manual design which was noticed was to attain 23-24 degree celcuis supply air through AHU and FCU
Client instructs to attain 20 to 21 degree celcuis on supply air
could this possibly results in getting low delta T or is it due to some other factors
25-01-2017, 02:29 PM #2
Re: delta t issue chilled water system
5-6 degrees delta T is fine, check for clean water filters and flow.
25-01-2017, 03:57 PM #3
Remind client that the system was designed for 23-24 and not 20-21.
25-01-2017, 06:02 PM #4
Delta t is directly related to water flow rate
28-01-2017, 07:40 AM #5
Thanks a lot for response given
whether trying to achieve low supply air temperature(like 20 and 21) limits impact delta t or does it results in starving of chilled water at the index lines
28-01-2017, 07:45 AM #6
Strainers on our secondary side got cleaned recently .
Constrain is that district cooling team supply the delta t as per the contract in the range 5-6 degree differential
When it comes to our side conditions are not met(like able to attain 3 degree celcuis max. delta T).Also supply temperature to our building get served @ 7.5degree celcuis with district cooling side been 4.5 degree
could you please help me in explaining why we come across such difference
28-01-2017, 10:30 PM #7
Check and reset if necessary the chilled water flow rates through chillers, higher flow rates will reduce delta T, due to high tube flow rates and water dwell / retention time, lack of heat exchange.
You have OEM manuals which should have commissioning settings per chiller set.Last edited by Magoo; 28-01-2017 at 10:32 PM. Reason: add
