Results 1 to 13 of 13
Thread: R-410a Gauge Pressure
24-10-2005, 02:36 PM #1
I am new to R-410a. Please can anyone tell what are the low & high side gauge pressures for a certain ambient temperature of a domestic airconditioner with R410a.
Thanks in advance
24-10-2005, 03:46 PM #2
Re: R-410a Gauge Pressure
Originally Posted by Mr.Sark
24-10-2005, 04:46 PM #3
Thanks Frank for replying, chart was very useful, but a domestic unit with R-410a, what is its design pressure? E.g With R-22 its Lowside 4bars & Highside 16 bars with an ambient temperature of 32deg C.
24-10-2005, 06:57 PM #4
With r410a on a heat pump split, the gauges are only useful for telling you if you have gas in the system or not, you cant tell the ambient temp by your gauges pressure on R410a i'm afraid.
cheers
24-10-2005, 11:32 PM #5
If you have a copy of the R410a pressure temperature chart, as provided by Frank, then you should be able to work out the pressures relating to the temperatures that you have measured.Brian - Newton Abbot, Devon, UK
25-10-2005, 09:02 AM #6
without sounding rude u should have some training on 410 also gauge connections r differrent
25-10-2005, 10:03 AM #7
Roughly said, split with R410A could be normal
LP - 8-10 bar
HP - 25-30 bar
25-10-2005, 11:06 AM #8
Hi Mr.Sark,
I don't think that there is such a thing as design pressure,
The unit is designed to maintain the evaporating temp above the freezing point,
It is done by adjusting the outdoor fan to the coil temp, regardless if its cooling or heating, assuming the system is charged as it should be.
only in sophisticated controls such as VRV and stuff, pressure is being monitored.
all th splits measure temps:
indoor temp,
indoor coil,
outdoor temp,
outdoor coil,
The rest is done by the controller.
410 is simply another refrigerant.
You will have to make sure though, that the copper tubing you use, will hold the higher pressure.
Hope I solved some of the mysteries.
Chemi
27-10-2005, 10:17 AM #9
while on 410 a can u suggest thickness of copper tubes to hold the pressure?
27-10-2005, 12:34 PM #10
Originally Posted by katyalrk
27-10-2005, 09:43 PM #11
Hope you " satisfied" this timeAny opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
30-10-2005, 04:33 PM #12
on the subject of r410 i know you are supposed to pressure test with nitro to 1.5x d.p is it the same for r410 given the fact that it has higher d.p and therefore may find the smallest weakness?>
30-10-2005, 08:15 PM #13
Richard, a strength test is a strength test regardless of the medium used.
Liquid Overfeed Systems
By US Iceman in forum NH3Replies: 151Last Post: 08-03-2007, 05:34 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
TEV capacity related to pressure drop
By DaBit in forum CPU OverclockersReplies: 8Last Post: 06-12-2002, 05:11 PM -
oil pressure problems on air dryer
By edge in forum Trouble ShootingReplies: 1Last Post: 16-07-2002, 02:10 PM
