    Dec 2012
    NZ
    5
    Whirlpool WBM39LW
    I have a Whirlpool wbm39LW. The alarm is beeping and the centre green light code is displayed. It sounds like something is trying to start (compressor? motor?) in sync with the alarm beeping. There is also a clicking sound from a black cylinder at the bottom rear of the fridge next to what I assume is the compressor. The serviceman said it needs a new circuit board ($500) but I'm hoping there's a cheaper option (hard start kit, capacitor kit??) Cheers
    Pete
    Nov 2012
    Uk
    43
    11
    Re: Whirlpool WBM39LW
    Sound like the Clixon ( current /heat overload on the compressor ) is clicking ie seized compressor or faulty condenser fan motor if you have 1 ... Could be faulty relay on pcb....or like you said faulty run capisitor if it has one .. Cheapest option is to by pass Clixon and test and or relay
    Dec 2012
    NZ
    5
    Hey, thanks very much for your help. Unfortunately as a civilian I have no idea what a Clixon is or how to bypass anything. I'll try to add a couple of photos and if there's anything more you can add it would be much appreciated! Cheers Petefridge 005.jpgfridge 001.jpgfridge 003.jpgfridge 004.jpg
    Jul 2006
    norfolk
    737
    does the compressor kick in and start or just make click click sound?
    check out my website www.airkooldomestics.co.uk
    Dec 2012
    NZ
    5
    Quote Originally Posted by tonto33 View Post
    Hi, It tries to kick in, for a split-second, each time in sync with the alarm beep & clicking.
    Jul 2006
    norfolk
    737
    then you have compressor fault
    Dec 2012
    NZ
    5
    Thanks. Could a faulty circuit board stop the compressor from kicking in properly?
    Jul 2010
    NTH.QLD Australia
    1,730
    32
    Quote Originally Posted by bearzac View Post
    The WBM's circuit boards don't generally show any sign of damage. I've changed quite a few over the years.
    Hope that price, on your initial post was not for just the module??
    A missed or failed compressor start on WBM's is 90% of the time caused by your PCB.
    Dec 2012
    NZ
    5
    Quote Originally Posted by mikeref View Post
    Hi, yes that was the quote to replace the circuit board, hence me looking for a cheaper fix, if it exists. Thought I might replace the capacitor since it's making the clicking noise (and only $17) Might work?
