Results 1 to 50 of 56
Threaded View
04-12-2010, 11:32 PM #29
Re: LG Multisplit ongoing issue... slowly getting there I think!
Paid £400 for reclaim, (no refrigerant loss whatsoever just slightly undercharged) so unit has exact refrirgerant weighed in as per LG.
However issues are still exactly the same. No change so I am not very happy.
WHen the system works it works very well however the next cycle on it may be very poor and air offs will be poor.
FOr example the other day when it was -2C outside an hour before I was getting air offs of 41C then an hour later air offs were 28C with no change if I put the set point upto 30C.
So I am back onto LG to see where they are going to take this next.
I still think its the EEV's as the outdoor unit main header pipe has higher temps than what gets to the indoor units. So its almost like the EEV's are not allowing enough gas through.Last edited by back2space; 04-12-2010 at 11:39 PM.
Daikin output overcurrent issue
By wilson77 in forum Air ConditioningReplies: 15Last Post: 18-01-2010, 11:36 PM -
Ongoing problem with Fuji ASTA12LLC
By Seiko in forum Air ConditioningReplies: 0Last Post: 03-11-2009, 02:51 AM -
Beko Fridge freezer - freezer temp issue
By lukas989 in forum DomesticReplies: 2Last Post: 30-09-2009, 05:29 PM -
Samsung Home Aircon Issue - Display Flashing
By dazzak in forum Air ConditioningReplies: 1Last Post: 03-07-2009, 05:05 PM -
Flood back issue?
By Arc in forum Trouble ShootingReplies: 15Last Post: 28-10-2008, 03:40 PM
