Thread: toshiba E04 fault
11-09-2010, 11:35 AM #1
toshiba E04 fault
Got a Tosh split compact cassette (indoor RAV562 ATE, outdoor MUT-E) keeps randomly showing E04 and shutting down.
The outdoor (first) AND indoor pcb's have been replaced, but it's still happening.
I've just been scrolling through a technical manual provided by one of you fine fella's and it mentioned..... fault code E04= Indoor unit receives no signal from outdoor, CAN "include klixon on 560 digital inverter" and says check by measuring voltage between capacitors.
Can anyone enlarge on that?
OR
Can anyone help please?Last edited by langy; 12-09-2010 at 06:56 AM. Reason: more info
12-09-2010, 08:12 PM #2
Re: toshiba E04 fault
OK does anyone know if the system was running slightly short of refrigerant and the klixon(if it has one) on the compressor tripped......could that come up as an E04 fault?????
13-09-2010, 01:31 PM #3
Toshiba Fault codes
By bernard in forum Air ConditioningReplies: 28Last Post: 03-08-2010, 11:09 AM -
toshiba a/c fault codes
By fsfd1 in forum Trouble ShootingReplies: 1Last Post: 30-09-2008, 07:10 PM -
toshiba fault codes
By COOL BOB in forum New to REReplies: 7Last Post: 09-12-2007, 08:18 AM -
Toshiba a/c fault codes
By Latte in forum Air ConditioningReplies: 3Last Post: 27-09-2007, 09:33 PM
