15-10-2009, 06:58 AM #1
Oil Migrates when Chiller is OFF!
Hi-
I'm new on the site, but it looks like a great resouce and to be honest I'm still pretty green in the commercial area.
I was wondering if anyone has experienced an oil migration problem like this: Carrier 19XR centrifugal 1500 ton R-134a machine loses oil gradually when it is shut down over the winter.
This past spring I had to add about 10 gallons of POE then remove it all after the stuff that migrated came back. Now that the cold is here, I am seeing the same thing happen. The chiller hasn't run for a couple of weeks now and the oil level in the sump has dropped below the lower sight glass.
We have a 30 minute "flush" through the condenser barrel every night to keep solids in suspension, but other than that the machine is completely idle. Any thoughts?
15-10-2009, 12:49 PM #2
Re: Oil Migrates when Chiller is OFF!
Check the crankcase heater it might not function.
15-10-2009, 05:49 PM #3
you need to shut all valves in on the compressor body when not using for a long time as when its cold outside where the unit is liquid tends to migrate to the coldest point and if thats outside where your unit is it will lift the oil.
09-03-2010, 09:07 PM #4
is th emachine turned off when not in use and shut down for the winter time,
if the machine oil pump is left on and the oip pump runs through its stir cycle after a period of time it is possible for the oil to leak through the labby.
10-03-2010, 08:53 PM #5
24-06-2010, 01:25 AM #6
What is the labby?
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
Power consumption of Chiller
By adrian116 in forum System OptimizationReplies: 7Last Post: 24-04-2009, 05:05 PM -
York Chiller startup when on Emergency Power
By Apollo10 in forum Trouble ShootingReplies: 3Last Post: 22-12-2008, 07:13 PM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM
