    hotrodinvi's Avatar
    hotrodinvi Guest
    Ice build up on the air conditioning high side
    hi
    just had a samsug mini split installed. worked fine for about 2 days. when i turned on the unit for about 5 minutes i noticed that it was only blowing hot air, when i check the out side unit the small copper line was covered in ice the bigger copper line was warm. i turned the unit off for about 10 minutes and then on again it did the same thing. what could be causing this problem.
    thanks for your help
    Feb 2010
    NT
    66
    Re: Ice build up on the air conditioning high side
    system is undercharge ckeck for leakage.check for trace of oil on the tail.between evap and condenser pipework.and all flarenut.All the best.
    3,853
    Get the installers back to check it over.
    hotrodinvi's Avatar
    hotrodinvi Guest
    Thank you I checked it and there is a leak thank you
  1. Side by Side TPG21PRXFBB
    By michel_engelen in forum Domestic
    Last Post: 26-05-2010, 08:57 AM
  2. Vac Down Procedure.
    By mendoza in forum Fundamentals
    Last Post: 26-09-2009, 04:19 PM
  3. A/C Pressure problem - Low side too high
    By Acrisoft in forum Air Conditioning
    Last Post: 17-09-2009, 12:14 PM
  4. samsung side by side sr-s2028css
    By sork in forum Technical Discussions
    Last Post: 26-06-2008, 09:06 PM
  5. Pressure relief valve
    By DaBit in forum Fundamentals
    Last Post: 16-08-2003, 03:11 PM
