Results 1 to 12 of 12
Thread: trane scroll compressor
19-04-2010, 04:21 PM #1
Hello, could anybody help me out on a trane scroll compressor, i need to no the tecnical information about a trane scroll with the model CSHA 150KE working with R407c, i need to replace it but donīt want to use trane , but an equivalent
19-04-2010, 08:39 PM #2
Re: trane scroll compressor
Some info here...
http://www.atilimsogutma.com/Folders/Trane.pdf
and here
http://www.americanhermetics.net/ass.../scrollsnc.pdf
also here
http://www.trane.com/commercial/uplo...tDALLAS.OK.pdfBrian - Newton Abbot, Devon, UK
20-04-2010, 07:03 AM #3
Hi :
trane scrolls are very expensive !that is why we use maneroupe comps as a replacment or even copeland ,the only problem is the minor change ,u must make on the pipe connections.
we have done this many times.
U should however clean the system very well after a burnout,to prevent this from repeating itself!Last edited by goshen; 20-04-2010 at 07:06 AM.
20-04-2010, 02:06 PM #4
Bitzer compressors are another more economical option
20-04-2010, 02:14 PM #5
21-04-2010, 01:03 PM #6
Those compressors are badge engineered for Trane. Some research will find the identical compressor, much cheaper (or it was last time I did it). Sorry but I can't recall for sure who makes them - might be Danfoss?
If it's on a manifolded circuit and it's burned out then it's generally best to replace both compressors if you can persuade the client to do so.
By the way, they can be bought alrady manifolded on the sub-base from the manufacturer - makes it much easier!
21-04-2010, 01:10 PM #7
21-04-2010, 07:37 PM #8
Actually the whole design is Trane. they sold the lisence to produce them to maneurope. That company was taken over by Danfoss. But the bottom line stays, it's a Trane designed compressor.
If it ain't broke, don't fix it!
21-04-2010, 10:11 PM #9
Well, of course. But I figured if I explained all that in my post, it'd get confusing!
All well in Holland, I hope?
21-04-2010, 11:12 PM #10
yeah, all well here! u?
22-04-2010, 12:42 AM #11
Good thanks. Beginning to cool down at last, but 95% of our work is maintenance so still busy. Will PM so we don't hijack the thread.
23-04-2010, 02:51 PM #12
scroll compressors are manufactured by trane at its plant in Monterrey Mexico
About Copeland ZB scroll compressor
By ernestlin in forum Technical SpeculationsReplies: 18Last Post: 27-08-2009, 08:39 AM -
scroll compressor failure
By sagar45 in forum Trouble ShootingReplies: 26Last Post: 07-06-2009, 03:56 PM -
[Autocascade] Only a project ATM
By before in forum CPU OverclockersReplies: 1Last Post: 07-05-2009, 11:13 AM -
Scroll Compressor Seizure
By jwasir in forum Trouble ShootingReplies: 9Last Post: 08-06-2008, 12:52 PM -
60Hz Copeland scroll compressor
By Lc_shi in forum FundamentalsReplies: 5Last Post: 05-06-2006, 09:08 PM
