Threaded View
19-04-2010, 04:11 PM #2
Re: liquid overfeed system ***** R404a
http://www.refrigeration-engineer.co...389#post179389
"Remember R-507(404A) is expensive, going 4-1 means you need to have a larger pipe to reduce the friction losses though the pipe. Also you will have a larger refrigerant charge. Your evaporator efficiency will go up with 4-1 but so will your costs. consider economizing on the liquid feed to say 2-1 or 3-1. This may save you money in the long run."
Remember just increasing the recirculation rate just mean your evaporator can be smaller. By reducing the recirculation rate your evaporator needs more surface area to maintain the same amount of cooling. Going higher than 4:1 will see very little improvment in the evaporator. (once all the tubes are "wet"-ed no additional benefit will occur with more liquid).
Refrigeration 101
By Gary in forum FundamentalsReplies: 201Last Post: 01-11-2011, 10:18 PM -
liquid not reaching TXVs in old rack system
By tropicold in forum Supermarket RefrigerationReplies: 20Last Post: 02-01-2010, 12:00 AM -
Over charged system... what symptoms?
By Clk320_Greg in forum Trouble ShootingReplies: 2Last Post: 19-10-2009, 06:25 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
