Results 1 to 16 of 16
Thread: A recent Job
05-03-2006, 01:41 PM #1
A recent job
Our latest work.
Counter in and out the trailer.
Panel made by my son.Last edited by Peter_1; 05-03-2006 at 01:53 PM.
05-03-2006, 01:43 PM #2
Re: A recent job
Some more pictures.
Job wasn't completely finished.The fans are now partially covered with Corian.
The enclosure for the compressor section is standing open just behind the inclined condensor with 3 circuits in it: counter, cooling rooms and airco.
One of the windows is open, the switches are for the fans in case there's failing one.
Fans are fed via a safety 220 VAC/220VAC transformer (humidity)Last edited by Peter_1; 05-03-2006 at 01:52 PM.
05-03-2006, 01:45 PM #3
Re: A recent job
As usual..it all has to fit in a very narrow space.
The counter was test running, you can see the frost on the plate.
Underneath the counter are 2 probes for controlling the temperature.Last edited by Peter_1; 05-03-2006 at 01:50 PM.
05-03-2006, 01:52 PM #4
Re: A recent job
Nice. is it just me or are the sol valves downstream of the driers?
05-03-2006, 02:05 PM #5
Re: A recent job
Euh.. sure...are you mounting those the other way perhaps
So you pump down each time your drier and sightglass in ice with every stop you make?
Why you're doing it the other way? I don't see it.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
05-03-2006, 02:13 PM #6
Re: A recent job
so you can pump over and change the drier
05-03-2006, 02:37 PM #7
Re: A recent job
http://www.sporlan.com/30-10.pdf
Read once this instructions very carefully http://www.ecopeland.com/Literature/...ADK__65018.pdfIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
06-03-2006, 10:17 AM #8
Re: A recent job
Lichuan,
What do you mean with practical result of the finished product?
AndHow about the offset with your target of the system?
We do many things without calculating, more by experience, these things grow while installing them.
Of course, we calculate many things but not everything.
What are you interested in specific?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
07-03-2006, 06:06 AM #9
Re: A recent job
Hi peter,
Sorry not to make myself clear on the expression
I mean : the difference between what your customer need and what you supply, if you've not done it before,i think you need make some calculation.Maybe you've already got the experience ,it should be no problem.
thanks and regards
26-06-2006, 07:19 AM #10
Re: A recent Job
Great job!Peter, a beautiful and mobility refrigerated display vehicle. I found the pipes before evap is very complex, does it have heat recovery?
26-06-2006, 09:50 AM #11
Re: A recent Job
Excelllent job Peter, As Ive said, bring this unit over to UK for a promotional tour
17-08-2009, 12:06 AM #12
Re: A recent job
ziet er goed uit me likes )
i am a fan
17-08-2009, 10:43 PM #13
Re: A recent Job
Heel goed!
21-08-2009, 11:02 PM #14
Re: A recent Job
Ek smaak jou werk baie boet.
22-08-2009, 03:32 PM #15
21-02-2010, 09:46 AM #16
Re: A recent Job
good job,it up
keep
A recent job
By Lc_shi in forum IndustrialReplies: 0Last Post: 06-03-2006, 09:15 AM
