Results 1 to 16 of 16
Thread: A recent Job
    Oct 2003
    56
    5,519
    28
    A recent job
    Our latest work.
    Counter in and out the trailer.
    Panel made by my son.
    Oct 2003
    56
    5,519
    28
    Re: A recent job
    Some more pictures.
    Job wasn't completely finished.The fans are now partially covered with Corian.
    The enclosure for the compressor section is standing open just behind the inclined condensor with 3 circuits in it: counter, cooling rooms and airco.
    One of the windows is open, the switches are for the fans in case there's failing one.
    Fans are fed via a safety 220 VAC/220VAC transformer (humidity)
    Oct 2003
    56
    5,519
    28
    Re: A recent job
    As usual..it all has to fit in a very narrow space.
    The counter was test running, you can see the frost on the plate.
    Underneath the counter are 2 probes for controlling the temperature.
    Sep 2005
    uk
    47
    504
    15
    Re: A recent job
    Nice. is it just me or are the sol valves downstream of the driers?
    Takes a licking, keeps on ticking.
    Oct 2003
    56
    5,519
    28
    Re: A recent job
    Euh.. sure...are you mounting those the other way perhaps
    So you pump down each time your drier and sightglass in ice with every stop you make?
    Why you're doing it the other way? I don't see it.
    Sep 2005
    uk
    47
    504
    15
    Re: A recent job
    so you can pump over and change the drier
    Oct 2003
    56
    5,519
    28
    Re: A recent job
    Oct 2003
    56
    5,519
    28
    Re: A recent job
    Lichuan,
    What do you mean with practical result of the finished product?
    AndHow about the offset with your target of the system?
    We do many things without calculating, more by experience, these things grow while installing them.
    Of course, we calculate many things but not everything.
    What are you interested in specific?
    Dec 2004
    Weihai,China
    807
    14
    Re: A recent job
    Hi peter,
    Sorry not to make myself clear on the expression
    I mean : the difference between what your customer need and what you supply, if you've not done it before,i think you need make some calculation.Maybe you've already got the experience ,it should be no problem.
    thanks and regards
    LC
    May 2006
    china
    98
    13
    Re: A recent Job
    Great job!Peter, a beautiful and mobility refrigerated display vehicle. I found the pipes before evap is very complex, does it have heat recovery?
    Apr 2001
    2,121
    21
    Re: A recent Job
    Excelllent job Peter, As Ive said, bring this unit over to UK for a promotional tour
    Feb 2009
    bruges
    42
    Re: A recent job
    ziet er goed uit me likes )
    i am a fan
    Aug 2008
    ireland
    75
    10
    Re: A recent Job
    Heel goed!
    Jul 2009
    South Africa
    73
    188
    10
    Re: A recent Job
    Ek smaak jou werk baie boet.
    Feb 2008
    manchester
    80
    11
    Re: A recent job
    Quote Originally Posted by slingblade View Post
    sol valves should always be after drier it can shatter the drier particals
    Jun 2009
    saudia arabian
    47
    21
    Re: A recent Job
    good job,it up
    keep
  1. A recent job
    By Lc_shi in forum Industrial
    Last Post: 06-03-2006, 09:15 AM
