Results 1 to 21 of 21
Thread: Unistrut
    Feb 2008
    IRELAND
    70
    Unistrut
    I need to mount a condenser on a non gable end out over the gutter to stop chavs stealing or damaging it.Unfortunately the eves and gutter stick out far enough that the condenser wont fit unless the cantilever arm is 900mm long. The units are on the small size and weigh around 40kg. Unistrut only do a 720mm long arm, is there anyway to extend this with an extension and is it safe?
    Britain
    220
    Re: Unistrut
    You can get some L brackets and make your own cantilever to the length that you need, you could also reinforce it by fixing a piece of channel cut at 45 degrees, with a bracket bolted top and bottom.
    If you ask your supplier for a Unistrut catalogue it will all make sense.
    Tutto il Mondo e un Paese
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    Yes i have had a look at the catalogue, the angle brackets dont seem safe in that it could pull out of the horizontal bar easily. I am thinking of a 750mm cantilever arm and a unistrut coupler perhaps reinforced with the angle as you say from underneath? This is probably safer as the back of the compressor at least will rest on the solid part of the cantilevered arm.
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    What is the best place to get the unistrut components needed in Dublin. Cheers
    3,853
    Re: Unistrut
    I'm sure our local ducting company sell 900mm unistrut style brackets, might be worth trying some different companies.
    Re: Unistrut
    Quote Originally Posted by lomb View Post
    Yes i have had a look at the catalogue, the angle brackets don't seem safe in that it could pull out of the horizontal bar easily.<snip>
    The forces on the horizontal arm would be downwards so there is not reason to expect a joint failure.
    I haven't seen that happen yet but if you are concerned then why not weld them together yourself?
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    I could i guess, but the idea of the standar cantilever bar + a joiner which is a square and wraps the unistrut for 15cm and 4 bolts mean it is unlikely to fail and is simple.
    Mar 2006
    belfast
    239
    Re: Unistrut
    why not just get a bracket made up urself. have seen many of these usaly for holding fridge condensers
    ireland
    1,453
    Re: Unistrut
    Lomb
    RDL and Fridge spares do a 900 arm
    alec
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: Unistrut
    Why not just use the cantilever brackets you have available, cut some unistrut to required length and bolt them to the original brackets?
    Andy
    Nov 2007
    Scotland
    67
    141
    Re: Unistrut
    If only it was that simple! Forces and Moments calculations is what you need to check.
    Does this look safe?
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    Quote Originally Posted by Andy AC View Post
    Andy
    This is what i will do but i need unistruts joiner that then bolts the segments together. Im not too worried about moments, its a 40kg unit and the wall is reinforced concrete what could possibly go wrong?
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    Quote Originally Posted by al View Post
    Lomb
    alec
    Thanks il try them if i cant get the extenders, what are 900mm arms used for normally some kind of industrial/fridge compressors?
    Feb 2008
    IRELAND
    70
    Re: Unistrut
    Quote Originally Posted by yinmorrison View Post
    Ive checked unistruts catalogue and the max weight at the very end of a 720mm arm is 65 kg and 80kg on a 600mm arm, therfore on a 900mm arm surely 40kg is ok,and the weight will be spread along a foot of that so should be safe!
    Aug 2004
    744
    Re: Unistrut
    Hilti do a 1000mm arm
    Eggs
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: Unistrut
    Use bolts and zebedees to hold the strut to the bracket, you don't need joiners.
    Andy
    woody1209's Avatar
    woody1209 Guest
    Re: Unistrut
    2 thoughts... you can get double width cantilever arms ie reinforced on the bottom so it is essentially 2 arms in one.
    Also if you fix unistrut vertically up the wall as opposed to simply anchoringthrough the eyes in the bracket you will get more fixings.
    Re: Unistrut
    The problem with this bracket is that the vertical arms fixed to the wall are too short.
    Made longer the load would be spread properly.
    5,667
    Re: Unistrut
    If you zoom in on that picture, you can see that the suction pipe suddenly reduces just before it connects onto the service valve
    Looks like 1+1/8 down to 3/4 or 5/8
    Aug 2004
    744
    Re: Unistrut
    Those new 10hp Tosh systems do that. I put one in the other day...1-1/8 suction reduced to a 7/8 flare connection......why?
    Eggs
    Re: Unistrut
    Quote Originally Posted by eggs View Post
    Eggs
    Ever tried doing a 1 1/8" flare ?
  1. What is the best way to mount a split to a wall?
    By paul_h in forum Air Conditioning
    Last Post: 28-09-2008, 03:57 PM
  2. Cutting unistrut
    By Andy AC in forum Tools and Calculators
    Last Post: 27-05-2007, 09:32 PM
