Thread: carrier 30HS
    Nov 2007
    Reading
    44
    5
    Question carrier 30HS
    Hello i hope someone can help, iam trying to find an O&M manual for a carrier 30HS chiller which has remote condensor's. I had a callout to an M&S site today and had trouble understand the controller. If anyone has any information on this chiller it will be much appreciated.
    Re: carrier 30HS
    Do you know which controller it is using?
    Aug 2007
    Sydney
    52
    1,083
    Re: carrier 30HS
    Hi Joeheath
    I've worked on many HS30 chillers, my 30 page manual is in NZ + I'm in Ausi - sorry. Some have had thier controllers replaced. They are pretty simple control usually with pumpout, pumpdown, hp/lp limmit and staging. Larger lead comps. Most faults I found are 1;vibration = 2;leak SOG = 3;log oil in evap and out on oil press. And the oil level 1/8 - 3/8 glass. Oil press req carlyle comp pocketbook, for memory 17 psi on old comp and 19 psi on newer comps. discharge mufflers are essential. 10k subcooling is good, 6k superheat at svalve. Valves - check heads - one side warm to hot, other cool to sweet. EEV check for moisture at terminals. EV tails leak. If you need more send a note to me.
    Ta Stu
    Nov 2007
    Reading
    44
    5
    Re: carrier 30HS
    I,am not sure what the controller is called, it has a number key pad 1-9 on the right and stat,serv,hist,ent,up&down keys next to it with a readout dislay above, i think it might be flotronic?
    Nov 2007
    IRELAND
    11
    Re: carrier 30HS
    Sounds like a flotronic controller, the keypad you describe sounds like a standard HSIO & if you key in 1 STAT & then press the down arrow you should get the info then 2 STAT & so on you should find most of the info you require.
    Give yourself a bit of time & most of the info should show itself pretty easy
    If you can get the model & serial I might be able to round up some info, those units must be getting a bit long in the tooth now if you have that style of controller
    Jun 2006
    South Coast
    278
    Re: carrier 30HS
    Your controller is a Flotronic 2 and was used on many of the 30 series chillers in the 90's. If you mention your email address i may be able to send you a copy of the controls book. Do you know the date of manufacture of your chiller and is it French or American made.
    Gibbo
    Nov 2007
    Reading
    44
    5
    Re: carrier 30HS
    Quote Originally Posted by Gibbo View Post
    Gibbo
    The date of manufacure was 1992, iam not sure weather it's french or american.
    if you have a copy of the controles book it will be much appreciated.
    Nov 2007
    IRELAND
    11
    Re: carrier 30HS
    Model & serial will tell where it was manufactured if you can get those.
    Jan 2009
    london
    52
    Re: carrier 30HS
    Hi gibbo, i noticed this post and I am in need for a control manual for a 30gh-150 flotronic , if you could help it would be much apprieciated, thanks troy
  1. Replies: 12
  2. Carrier Pro Dialog Plus help
    By borodave1973 in forum Air Conditioning
    Last Post: 11-11-2007, 06:47 PM
  3. Carrier Chiller Help
    By superswill in forum Trouble Shooting
    Last Post: 18-01-2007, 10:06 PM
  4. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
  5. carrier remote
    Last Post: 26-04-2006, 09:17 PM
