    Jun 2007
    Leicester
    44
    Carrier Pro Dialog Plus help
    Hi have just fitted a new pcb to a carrier 30GG 045-911E chiller after it blew but on firing the system back up the word COnF appears in the display for the pro dialog plus controller. In the manual it says that the basic board needs configuring and that this can only be carried out by a carrier service engineer.
    Just wondering if anyone knows how to do this as don't really want to spend more money on getting carrier out as the pcb cost a small fourtune.
    Thanks for any help
    Apr 2006
    stafford
    36
    986
    14
    Re: Carrier Pro Dialog Plus help
    i had the same prob,but with having done very little on these systems,i had carrier out,but was on holiday when they attended,and never went back to site so would like to know the outcome/answer to this
    Paul
    "KEEP IT COOL"
    Aug 2003
    Netherlands
    43
    621
    15
    Unfortunally you can't do it yourself, you need a laptop with the right software to do it! So getting Carrier out is the only option!
    Nov 2007
    IRELAND
    11
    The conf means the unit has lost or has no configuration. The unit board reverts to this mode when it is new or the eeproms are removed or the backup battery has failed. The best thing would be to get Carrier out or to save on cost's (they never really want to spend anymore money do they) you could take the board to carrier & get them to do it at their base you will need the 88CS code these should be located just underneath the main board & should have a code something like 88CS3000VA300010EE. There are 2 lines of code TAKE BOTH OF THEM DOWN EXACTLY. They should be able to do this for you as it only takes a 24V power supply to the board to enable reconfiguration.
    Why did you need to replace the board in the first place? Just wondering only you don't want to have to buy another.
    Nov 2007
    Dubai
    12
    Quote Originally Posted by borodave1973 View Post
    Thanks for any help
    how much is carrier's charge
    Jun 2007
    Leicester
    44
    The board kept blowing the transformer not a problem now just need to get carrier out not cheap at 550 just wish someone at carrier had told us this when we purchased board
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. Carrier chiller basic board problem
    By noushad123 in forum Trouble Shooting
    Last Post: 17-06-2010, 06:55 AM
  3. Carrier Chiller Help
    By superswill in forum Trouble Shooting
    Last Post: 18-01-2007, 10:06 PM
  4. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
  5. carrier remote
    Last Post: 26-04-2006, 09:17 PM
