Results 1 to 32 of 32
Thread: Panasonic Fault codes
Threaded View
31-07-2009, 01:08 PM #20
Re: Panasonic Fault codes
Some panasonic non inverter fault codes
f15 - drain level float switch
f16 - louver switch
f17 - dc fan motor
f20 - indoor temperature sensor
f21 - pipe temp sensor (indoor)
f26 - remote control transmission
f27 - indoor outdoor unit disconnected
f30 - system problem
f31 - suction pressure protection
f32 - compressor overcurrent frotection
f40 - heat exchanger outlet temperature sensor
f41 - high pressure switch open circuit
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
carrier chiller fault codes
By al in forum Air ConditioningReplies: 7Last Post: 20-07-2009, 10:10 PM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
Chigo Cpa-09co Fault Codes? E4?
By chigosimon in forum Trouble ShootingReplies: 5Last Post: 24-11-2007, 12:46 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
