Results 1 to 32 of 32
    Jan 2005
    Ireland
    37
    84
    15
    Panasonic Fault codes
    Hey everyone,
    I really hope someone can help, im looking for fault codes for a panasonic a/c system. The serial number on the outdoor unit is CU-140C53XP and the error codes are F15 and F41 . What a nightmare panasonics website offers no support for this unit.. help
    70
    10,575
    52
    Re: Panasonic Fault codes
    Hi Ronald, welcome to the forum.
    Likewise I couldn't find your model on the Panasonic site, did you get to this page---
    http://www.panasonic.com/consumer_el...ac/manuals.asp
    there might be a similar control setup on one of those; might be worth a look.
    Dec 2004
    Australia
    519
    14
    Quote Originally Posted by ronaldo9
    Hey everyone,
    G'day Ronaldo
    Have got a fault code list here may or may not be relevant to your unit.
    F15=Drain level float switch problem.
    F41= High pressure switch open circuit problem (3 LED's illuminated on outdoor PCB).
    or
    Low pressure sensor problem. (2 LED's illuminated on outdoor PCB).
    Regards.
    ireland
    47
    1,288
    34
    Ronaldo,
    ring walkair in dublin, ask for service dept,. they're really easy to deal with
    014568070
    Alec
    MOUNIR COOLING's Avatar
    MOUNIR COOLING Guest
    hi
    looking for sanyo inverter error code please. sure someone can help.
    70
    10,575
    52
    Quote Originally Posted by MOUNIR COOLING View Post
    hi
    Not under Panasonic I wouldn't think
    Oct 2006
    Bucks, U.K.
    65
    604
    12
    Mounir....start a new thread under Aircon....also have a search. What system SAP or SRW
    ECM
    Oct 2007
    malaysia
    7
    Quote Originally Posted by Temprite View Post
    G'day Ronaldo
    or
    Regards.
    hello Temprite i got a problem in Panasonic ceiling casstle single spit unit my problem is fan coil and the condenser stop at the same time and the outdoor unit LED 2,3,5,7 light up so how to solve this problem?thanks in advance
    Regards.
    Jul 2007
    Australia
    44
    1,857
    14
    Should be current detect pcb faulty, or compressor drawing too much current.
    I don't have your model a/c, but panasonic fault codes stay pretty much the same
    Normally panasonics have this info on the inside of the access panel.
    Plus fault codes from the indoor unit make it easier to look up.
    if the compressor is running, check the amps and refrig pressures.
    Apr 2008
    Australia
    48
    I know this is a old thread but did someone have luck in locating service/install manual for Panasonic CU-140c53XP. I have one of those lovely jobs to help a neighbor install this system that he purchased at auction. I cant find any info on the capacity, etc other then model number. Regards
    Sjonnie's Avatar
    Sjonnie Guest
    Hey all ... also got a Panasonic airconditioning here. It's got fault code F22, any idea what the Panasonic means?
    Jul 2007
    Australia
    44
    1,857
    14
    Depends on the model. Conventional ducted, old split, newer inverter etc.
    To be honest, I have a lot of panasonic fault codes and manuals, none of them have F22.
    But if you have the model number, maybe someone can find it.
    Apr 2007
    Rainham, Essex
    37
    64
    12
    I came across a Panasonic unit today with an E9 Fault Code.
    Indoor model number, CS-125U1HPP.
    Outdoor model U-100H2SPP.
    I spoke to Climate Tech and got a lot of info from them, 08705 218218
    panaloni's Avatar
    panaloni Guest
    where can I get a service manual for a panasonic wall split model: cuw24dkr with indoor csw24dkr
    Jul 2007
    Australia
    44
    1,857
    14
    Well being as that's a conventional unit, there's not a lot of useful info in the manual anyway. It's pretty much the same as every other conventional model service manual word for word.
    What do you need to know?
    Sep 2005
    london uk
    47
    9
    hi paul,
    panasonic cu-112c52hp out door unit,
    do you know the fault code if42, even better if you have the fault code list.thanks
    Jul 2007
    Australia
    44
    1,857
    14
    probably compressor current trip.
    Is there nothing in the outdoor unit with fault codes?
    oldgit's Avatar
    oldgit Guest
    That model is a Daikin/Panasonic unit. So the fault code will be the same as the Daikin codes.
    From memory E9 was related to a Electronic Expansion valve fault.
  19. #19
    oldgit's Avatar
    oldgit Guest
    Talking Re: Panasonic Fault codes
  20. #20
    May 2008
    106
    10
    Some panasonic non inverter fault codes
    f15 - drain level float switch
    f16 - louver switch
    f17 - dc fan motor
    f20 - indoor temperature sensor
    f21 - pipe temp sensor (indoor)
    f26 - remote control transmission
    f27 - indoor outdoor unit disconnected
    f30 - system problem
    f31 - suction pressure protection
    f32 - compressor overcurrent frotection
    f40 - heat exchanger outlet temperature sensor
    f41 - high pressure switch open circuit
  21. #21
    Oct 2001
    Nottingham UK
    5,121
    42
    Nice one Jay
    I'm back on the Pale
  22. #22
    JRMAIR's Avatar
    JRMAIR Guest
    HEY EVERYONE
    Im looking fault codes for a panasonic inverter the model is CU-E12-EKU and the fault code is f93
  23. #23
    Feb 2008
    QLD
    48
    74
    11
    F93 compressor abnormal revolution
    Check compressor windings (all 3 windings should be the same)
    check output from inverter with inverter checker
  24. #24
    shaday's Avatar
    shaday Guest
    I want know about error codes for panasonic inverter air-conditioner
  25. #25
    Feb 2008
    QLD
    48
    74
    11
    Post the fault code,and model number, and we may be able to assists :-)
  26. #26
    proudlock's Avatar
    proudlock Guest
    How you going, i have a cs-e18dkr with fault code H23, what does this mean, Thanks,
    Rob
  27. #27
    Apr 2005
    Manchester England
    37
    332
    14
    Indoor Pipe Sensor Faulty Sensor Disconnected, Faulty or Contacts Dirty
    cheers lee
  28. #28
    May 2001
    North Wales
    47
    Hi I have "F3" Fault code on Panasonic CU10ME1XPK
    Any ideas please I think discharge sensor fault but what causes this they have been changed and still same fault
  29. #29
    Aug 2009
    east anglia
    43
    95
    9
  30. #30
    May 2001
    North Wales
    47
    Many thanks I misled you with fault code sorry it should have been 'J3' this indicates a sensor fault I think?
    The link is good but not for my model mine is CU-10 ME1XPK If you have got another link that would be great?
    Thanks,
  31. #31
    Aug 2009
    east anglia
    43
    95
    9
    Quote Originally Posted by Gwyn View Post
    Thanks,
    Yes you are right it is the indoor air sensor
    Attached Files Attached Files
  32. #32
    May 2008
    33
    Thanks guys!
  1. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  2. carrier chiller fault codes
    By al in forum Air Conditioning
    Last Post: 20-07-2009, 10:10 PM
  3. Daikin fault codes
    By Markie in forum Air Conditioning
    Last Post: 13-01-2009, 01:58 AM
  4. Chigo Cpa-09co Fault Codes? E4?
    By chigosimon in forum Trouble Shooting
    Last Post: 24-11-2007, 12:46 AM
  5. MHI, Sanyo & Fuijitsu Complete Fault Codes
    By aeb200 in forum Air Conditioning
    Last Post: 16-11-2005, 01:11 PM
