Results 1 to 32 of 32
Thread: Panasonic Fault codes
25-03-2006, 10:47 PM #1
Hey everyone,
I really hope someone can help, im looking for fault codes for a panasonic a/c system. The serial number on the outdoor unit is CU-140C53XP and the error codes are F15 and F41 . What a nightmare panasonics website offers no support for this unit.. help
25-03-2006, 11:42 PM #2
Re: Panasonic Fault codes
Hi Ronald, welcome to the forum.
Likewise I couldn't find your model on the Panasonic site, did you get to this page---
http://www.panasonic.com/consumer_el...ac/manuals.asp
there might be a similar control setup on one of those; might be worth a look.Brian - Newton Abbot, Devon, UK
26-03-2006, 04:23 AM #3
Originally Posted by ronaldo9
Have got a fault code list here may or may not be relevant to your unit.
F15=Drain level float switch problem.
F41= High pressure switch open circuit problem (3 LED's illuminated on outdoor PCB).
or
Low pressure sensor problem. (2 LED's illuminated on outdoor PCB).
Regards.
26-03-2006, 09:29 PM #4
Ronaldo,
ring walkair in dublin, ask for service dept,. they're really easy to deal with
014568070
Alec
06-03-2007, 11:00 PM #5
hi
looking for sanyo inverter error code please. sure someone can help.
06-03-2007, 11:15 PM #6
06-03-2007, 11:30 PM #7
Mounir....start a new thread under Aircon....also have a search. What system SAP or SRW
ECM
14-10-2007, 12:24 PM #8
17-10-2007, 10:45 AM #9
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
01-08-2008, 07:09 AM #10
I know this is a old thread but did someone have luck in locating service/install manual for Panasonic CU-140c53XP. I have one of those lovely jobs to help a neighbor install this system that he purchased at auction. I cant find any info on the capacity, etc other then model number. Regards
03-09-2008, 02:32 PM #11
Hey all ... also got a Panasonic airconditioning here. It's got fault code F22, any idea what the Panasonic means?
03-09-2008, 02:47 PM #12
Depends on the model. Conventional ducted, old split, newer inverter etc.
To be honest, I have a lot of panasonic fault codes and manuals, none of them have F22.
But if you have the model number, maybe someone can find it.
27-02-2009, 10:08 PM #13
I came across a Panasonic unit today with an E9 Fault Code.
Indoor model number, CS-125U1HPP.
Outdoor model U-100H2SPP.
I spoke to Climate Tech and got a lot of info from them, 08705 218218
29-06-2009, 03:21 PM #14
where can I get a service manual for a panasonic wall split model: cuw24dkr with indoor csw24dkr
01-07-2009, 05:34 PM #15
Well being as that's a conventional unit, there's not a lot of useful info in the manual anyway. It's pretty much the same as every other conventional model service manual word for word.
What do you need to know?
31-07-2009, 12:13 AM #16
hi paul,
panasonic cu-112c52hp out door unit,
do you know the fault code if42, even better if you have the fault code list.thanks
31-07-2009, 05:07 AM #17
probably compressor current trip.
Is there nothing in the outdoor unit with fault codes?
31-07-2009, 12:23 PM #18
That model is a Daikin/Panasonic unit. So the fault code will be the same as the Daikin codes.
From memory E9 was related to a Electronic Expansion valve fault.
31-07-2009, 12:24 PM #19
31-07-2009, 01:08 PM #20
Some panasonic non inverter fault codes
f15 - drain level float switch
f16 - louver switch
f17 - dc fan motor
f20 - indoor temperature sensor
f21 - pipe temp sensor (indoor)
f26 - remote control transmission
f27 - indoor outdoor unit disconnected
f30 - system problem
f31 - suction pressure protection
f32 - compressor overcurrent frotection
f40 - heat exchanger outlet temperature sensor
f41 - high pressure switch open circuit
31-07-2009, 08:23 PM #21
Nice one Jay
13-08-2010, 12:50 AM #22
HEY EVERYONE
Im looking fault codes for a panasonic inverter the model is CU-E12-EKU and the fault code is f93
13-08-2010, 01:24 AM #23
F93 compressor abnormal revolution
Check compressor windings (all 3 windings should be the same)
check output from inverter with inverter checker
15-10-2010, 07:17 AM #24
I want know about error codes for panasonic inverter air-conditioner
18-10-2010, 12:01 AM #25
Post the fault code,and model number, and we may be able to assists :-)
01-11-2010, 08:37 AM #26
How you going, i have a cs-e18dkr with fault code H23, what does this mean, Thanks,
Rob
01-11-2010, 06:58 PM #27
Indoor Pipe Sensor Faulty Sensor Disconnected, Faulty or Contacts Dirty
cheers lee
07-12-2010, 09:48 PM #28
Hi I have "F3" Fault code on Panasonic CU10ME1XPK
Any ideas please I think discharge sensor fault but what causes this they have been changed and still same fault
13-12-2010, 02:37 PM #29
Panasonic Fault Codes Below....
http://www.mediafire.com/download.php?0f53eejjp271doa
13-12-2010, 11:14 PM #30
Many thanks I misled you with fault code sorry it should have been 'J3' this indicates a sensor fault I think?
The link is good but not for my model mine is CU-10 ME1XPK If you have got another link that would be great?
Thanks,
13-12-2010, 11:33 PM #31
20-02-2011, 08:57 PM #32
Thanks guys!
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
carrier chiller fault codes
By al in forum Air ConditioningReplies: 7Last Post: 20-07-2009, 10:10 PM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
Chigo Cpa-09co Fault Codes? E4?
By chigosimon in forum Trouble ShootingReplies: 5Last Post: 24-11-2007, 12:46 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
