    Jun 2009
    France
    7
    R407 inside unit on old R22 compressor ?
    hello
    I have an old Daikin 3 way multisplit with R22 at my house. There is only 1 (out of the possible 3) inside units connected and I want to add an extra unit. Can I add a newer inside unit that has been used with R407 ?.
    May 2006
    Isle of Wight, Uk
    47
    424
    Re: R407 inside unit on old R22 compressor ?
    The electronics on the newer unit might not be compatible.
    Andy
    Jun 2009
    France
    7
    Electrics are ok - interface is a single wire to switch the outside unit on or off by a relay (240v=on 0V=off)
    So there is no issue with the diffferent fluids then ?.
    Nov 2008
    136
    hello, you could flush out the coil, new copelands. most new compressors come out with poe oil and R22 will still run if there is a little bit of poe and mineral oil.
    someone who knows a bit more will be spot on.
    May 2008
    66
    802
    if it is a new unit,never being used,and the system is on/off,then there is no problem and it will work just fine. just don't expect that the R407 unit have the same quality as the R22 unit. if it is a used one,R407C,clean fermly the inner tubing,because the POE (polyester ether) oil will damage the mineral oil based compressor.
    good luck, Ice
    Jun 2009
    France
    7
    The indoor unit is an Airwell that is sold for R22 and R497 use. The actual unit I plan to use has been previously used with R22 - but I plan to add two more units (so I 'll try to get these new).
    Many thanks for the advice.
    Split Croatia
    6,151
    May 2008
    66
    802
    so the outdoor unit is a Daikin and now there is an Airwell indoor on. or you are going to hang an Airwell unit on a Daikin ??
    a bit confusing no ?? i don't think you can mount an Airwell indoor on a Daikin outdoor unit,ore the electricals has being fermly changed and work like an on/of system. even do, good luck.
    Ice
  1. [Autocascade] Only a project ATM
    By before in forum CPU Overclockers
    Last Post: 07-05-2009, 11:13 AM
  2. How to Design Refrigeration Systems
    By US Iceman in forum Fundamentals
    Last Post: 24-07-2008, 04:27 PM
  3. Change over 2 outdoor unit
    By bach in forum Air Conditioning
    Last Post: 08-06-2008, 06:55 PM
  4. Replies: 5
    Last Post: 22-06-2005, 07:41 PM
  5. Compressor failure...... cause
    By herefishy in forum Technical Speculations
    Last Post: 06-12-2002, 12:15 AM
