Thread: G50 fault codes
21-05-2009, 05:51 PM #1
G50 fault codes
I started a maintenance visit today at a site with a G50 controller.
After scrolling through the G50 i found one of the numers flashing a fault. It is a losnay (vam).
I went into option 4 which lists the faults and it said 035.0900 detect 035, i then reset it and i got the error code 035 0900 detect 008.
I've been on the mitsi website to try and find the fault but i can't find it.
I'm sure when i get to site tomorrow i will be able to find what the problem is anyway but the fault code will make it a little bit easier
Marc
21-05-2009, 06:52 PM #2
Re: G50 fault codes
Fault Code 0900 = Test run lossnay unit, Dipswitch SW2,1 and SW2,3 on apparently!
Not sure if that helps or not!He who dies with the most Toys, WINS!
21-05-2009, 08:09 PM #3
Re: G50 fault codes
Yes that does help thanks.
We have taken over the maintenance of a building but the kit is pretty new so the origional installers must have left it like that.The difference between genius and stupidity is that genius has its limits.
Marc
24-05-2009, 05:07 PM #4
Re: G50 fault codes
Marc- I can't believe your company have taken on another Mitsu' VRF building after your last gas leak nightmare post!!
Sounds like this site will give you less sleepless nights!
"I'm anaspeptic, frasmotic, even compunctuous to have caused you such pericombobulation."
24-05-2009, 10:59 PM #5
Re: G50 fault codes
Most of the sites we work on have Mitsubishi VRF's that we look after.
Are you saying that because i had a nightmare trying to find the leak that was caused by the nail in the pipework, that my company should not take on any more mitsubishi contracts?
Surely notThe difference between genius and stupidity is that genius has its limits.
Marc
25-05-2009, 07:37 AM #6
Re: G50 fault codes
No of course not, we all need any contracts we can get at the moment!
Its just when I saw your avitar the whole story came back to me!"I'm anaspeptic, frasmotic, even compunctuous to have caused you such pericombobulation."
25-05-2009, 09:51 AM #7
Re: G50 fault codes
Ah ok sorry. I think that job will stick in my mind for a very long time and it will definatly help me next time i have a hard to find leak.
Marc
26-05-2009, 06:48 PM #8
Re: G50 fault codes
Tell you what Marc if you want to upset your Boss/Client and haven't priced them already ask your Mitsi supplier for a quote for a set of replacement filters for the Losnay Heat Exchanger units!
Panasonic Fault codes
By ronaldo9 in forum Air ConditioningReplies: 31Last Post: 20-02-2011, 08:57 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
standardisation of fault codes?
By kelvin kline in forum Air ConditioningReplies: 1Last Post: 10-10-2007, 12:30 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
