    philrobson's Avatar
    philrobson Guest
    Angry FFA 71 freezer caput....fridge freezing up
    I have a similar problem to a previous thread where, the freezer no longer works and the fridge is freezing everything in it, I know that the previous thread had many suggestions but nothing definative, I don't really want to fork out for a new board at £90 if that is not the problem any help appreciated
    phil
    Aug 2007
    Perth
    44
    Re: FFA 71 freezer caput....fridge freezing up
    I'm not familiar with the make or model but it could be an airflow problem.
    Some of these fridges have a thermostatically controlled damper controlling the air flow to the fridge. If this was wide open it would cause stuff to freeze in your fridge and a possible higher temp in your freezer.
    It is unusual however for it to fail open...
    Just a thought...
    philrobson's Avatar
    philrobson Guest
    thanks but I dont think thats it
    Oct 2006
    1,843
    Quote Originally Posted by philrobson View Post
    Some fridge-freezers have a magnetic valves that control the flow of refrigerant through the systems.
    If the fridge is working but the freezer is not and it has one compressor then I could suggest that the valve or control to the valve for the freezer is not working (if it is that type).
    Other than that you may have to pay for an engineer to look at it.
    taz.
    May 2008
    Malta
    68
    67
    Please be more specific, is the fridge a no frost ,one compressor or two electronic thermostat or mechanical.
  1. Hotpoint FF200E Fridge Freezer Fault
    By fredalfred in forum Domestic
    Last Post: 29-12-2012, 01:26 PM
  2. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  3. Replies: 4
    Last Post: 15-06-2008, 09:42 AM
  4. Replies: 11
    Last Post: 16-03-2008, 07:12 PM
  5. Help! fridge freezer probs
    By Glenreed in forum Trouble Shooting
    Last Post: 06-01-2006, 10:51 PM
