    Glenreed's Avatar
    Glenreed Guest
    Help! fridge freezer probs
    Hi, just wondered if someone could help me? i am not a fridge expert but i do sometimes deal with aircon at work on lorries, about 18 months ago we bought a beko fridge freezer unit and yesterday it died and all our food defrosted, the inside light was opperating but i could not hear the compressor running or the circulation fan in the freezer compartment so i proceded to check all wires and connectiontions for continuityfound i had power into the unit ok and up to the adjustable thermostat in the fridge but no power from the black wire out of the thermostat wich as far as i could trace ran to the motor via a couple of units wich i assume were some kind of switches? on closer inspection of the thermostat i found a small brass screw wich was screwed in about half way i unscrewed the screw fully and found there was a brass tag underneith it so i reinserted the screw power up the unit and screw it in after a few turns the compressor and circulating fan burst into life so i reassembled the unit and left it to run on the lowes (warmest) setting the freezer has frozen the ice cube tray and the fridge is cold maybe a little to cold although its on the lowest setting now i have a small ice build up in the back of the fridge and the circulation fan continusly runs wich i dont remember it doing befor also the compressor does the same, the compressor also is very hot i can just about hold my hand on it for about 3 seconds
    Anyone got any ideas? is this normal?
    many thanks Glen
    Apr 2001
    2,121
    Re: Help! fridge freezer probs
    Glen
    It looks like a stat problem.
    Im not familiar with this type of fridge, I think the brass screw youve turned in may be the stat adjustment
    Try taking a pic and post
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    69
    10,484
    Yep Glen you have now de-calibrated the thermostat.
    It is possible that it was faulty already so don't feel too guilty.
    The compressor can run hot depending on the load and length of running time; if it was too hot then the safety switch on the compressor would probably trip and shut it down.
  1. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  2. zanussi fridge freezer
    By johnny-dolla in forum Domestic
    Last Post: 03-08-2006, 09:27 PM
  3. fridge freezer
    By mpoh@supanet.co in forum Domestic
    Last Post: 01-06-2006, 07:42 AM
  4. Brandt Apollo Upright Fridge Freezer
    By marto in forum Trouble Shooting
    Last Post: 06-04-2006, 09:59 AM
  5. Freezer not cold enough, Fridge too cold
    By barrance in forum Commercial
    Last Post: 06-12-2001, 07:11 PM
