Results 1 to 16 of 16
Threaded View
12-06-2008, 10:12 AM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Charging liquid through suction line?
I will describe how I do it when I charging thru low side.
If I know total amount, I charge by weight reading the amount drawn on scale and throttling on manifold valve.
I usually keep rate of charging by 2-5% (higher at beginning and lower at the end of charging process) of total charge in one minute, while watching that sight glass on my Refco 4 valve manifolds is not full of liquid (I keep sight glass with lots of bubbles). After 1/2 to 1 minute, I stop feeding refrigerant and wait for another minute or two that accumulated refrigerant (if any) evaporates. Then I start feed refrigerant again.
If I don't know total amount, I charge slowly, keeping sight glass on manifolds without liquid and interrupting frequently to check pressures. When they are near to be good, I look in scale and proceed with charging about 1-2% of total amount charged so far.
Now, I measuring subcooling, after some time system stabilize, and judging if it is more needed.
That is my way, which I adopted from my experience and after reading a lot of articles about proper charging methods. It works relatively fast and it is accurate and don't make any damage to system.
Superheat and Subcooling
Liquid charging through the suction side
By deu58 in forum FundamentalsReplies: 13Last Post: 02-07-2010, 05:23 AM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM
