Thread: imperical formula
30-04-2008, 08:31 AM #1
imperical formula
hello good day...... what is the imperical formula in solving the tonnage requirement of a building with a given floor area and floor to ceiling height of 3 meters. thank you and more power
30-04-2008, 10:04 AM #2
Re: imperical formula
hi everybody.... good morning..... can anybody let me know the method of calculating the "COP" of a "CLOSED" as well as "OPEN" system.....
regards
30-04-2008, 12:11 PM #3
good day...does anyone knows what is the required ton of refrigeration needed for a volume of 1 cu.m. or an area of 1 sq.m? ( empirical value)
thanks.......
01-05-2008, 09:42 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Heat load doesn't depend directly on volume or surface of building.
It depend on heat gain from surrounding walls, ceiling, floor, windows, quantity and quality of fresh air, number of occupants end heat generated from different heat sources in rooms.
You need to know all these data, and then you could calculate required ton of refrigeration needed.Last edited by nike123; 01-05-2008 at 09:47 AM.
03-05-2008, 07:42 AM #5
thanks nike 123...... thats exactly some of the requirements to get the cooling load of the space to be conditioned. What i mean is that can we used some data which is not written in the book; like 14 square meter/ton or 150watts/cu.m. to get the required tonnage of the space to be conditioned?
04-05-2008, 11:31 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
That is called "rule of thumb", and rule of thumb doesnt take in consideration all above said. They are mainly used in spaces with common building practice and by experienced installer could be well on right track.
As you know, there is lot of different building practices and climatic conditions for any rule of thumb to be of universal value.
I know, for my town, in some new buildings and flats oriented at South that 120W/m^2 is good rule of thumb, but that could be pretty much off for some other house 50m from that flat (or at same building like top floor flat or basement flat). Also, flat oriented at North-East or North-West could need much more heating capacity then that oriented to South. For that same building my rule of thumb is, in that case, 150W/m^2.Last edited by nike123; 04-05-2008 at 11:39 PM.
11-05-2008, 10:33 AM #7
nike 123..... thank you for your explanation about the rule of a thumb.
11-05-2008, 10:40 AM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
11-05-2008, 10:42 AM #9
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
This thread is totally of topic!
The original poster has newer got any answer and this is gone in different direction!
11-05-2008, 10:51 AM #10
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Please, define closed and open system or give some example!
Generally COP is is relationship of useful heat supplied by condenser and work consumed by compressor:
This is second result when you type COP in Google search box.
http://tinyurl.com/65g3zo
11-05-2008, 06:21 PM #11
Rules-of-thumb are OK to use if you want to verify the installed capacity or want to do a sanity check to quickly develop some concepts for troubleshooting. They should not however be used for design purposes.
As nike123 pointed out the rules-of-thumb are usually based on some general conditions to be valid. If the specific operating conditions exceed the assumptions used in the rule-of-thumb you can have problems.If all else fails, ask for help.
R22 Temp To Pressure Formula
By lwarren in forum Tools and CalculatorsReplies: 76Last Post: 29-11-2008, 08:46 PM -
Charging formula
By piashaw in forum FundamentalsReplies: 7Last Post: 25-09-2007, 12:25 PM -
Formula to Calculate
By suny in forum FundamentalsReplies: 7Last Post: 09-08-2007, 02:38 AM -
Formula to size Refer unit for Beverage cooler
By mccoolair@yahoo in forum CommercialReplies: 9Last Post: 25-01-2006, 08:42 AM -
Charging formula
By zimbo in forum Trouble ShootingReplies: 5Last Post: 28-12-2005, 10:11 PM
