Page 1 of 2 12 LastLast
Results 1 to 50 of 77
    Mar 2008
    Angry R22 Temp To Pressure Formula
    I am trying to write a computer program that calculates the pressure of R22 from a given temp, just like a p/t chart.
    I have searche the web an have not been able to find a formula. Does anyone know what this formula is?
    Aug 2005
    5,302
    Re: R22 Temp To Pressure Formula
    Find a set of tables for the refrigerant you want to use. Then plug the data into an Excel spreadsheet. One column for temperature and another for pressure. Then you can curve fit the data so that your program calculates the pressure from the temperature input from the instruments.
    You may have to turn on the Data Analysis option in Excel, but it's in there. Look in the Help section (F1) and search for curve fitting or regression as the topic.
    The temperature to pressure works out quite well, but going from pressure to temperature with this method is a little dicey.
    Feb 2008
    Norway
    57
    446
    Interesting problem. I made a heat pump where i wished to read out the condensing and evaporator temperature on the PLC from a pressure transducer. I was looking for a formula that i could program the plc with so it could convert pressure to temperature. I wasnt able to find a formula.
    I doubt there exists a simple formula. At least if it should give an accurate result. If someone has a formula, simple or complicated, i'm also very interested in it.
    Feb 2008
    Norway
    57
    446
    Is it possible to read out the actual formula from Excell? I need a formula i can incorporate in my PLC program.
    Mar 2008
    Quote Originally Posted by SteinarN View Post
    That is what I am trying to do, I need to write a custom program object for an energy managment system.
    I know the formula exists, because there are online caclculators that do this.
    The Excel option will not work for me.
    Feb 2008
    Norway
    57
    446
    I know some compressor calculation software uses formulas and not tables to calculate capasity. Danfoss does this. You can read out the formula as well as the values for each compressor that you put in the formula (an universal formula but different values put into that formula dependent on which compressor to calculate). I tried to make a formula myself a couple year ago, but I didnt have enough time to have a serious try. Maybe i should try one more time.
    Mar 2008
    If you figure it out, let me know. It is not a linear formula, or it would be fairly easy.
    Aug 2005
    5,302
    Quote Originally Posted by lwarren
    Why? All you have to do is as I suggested and then paste the equation (that Excel generates for you) into your PLC program. It will be as accurate as you need for the program.
    Mar 2008
    Sorry Iceman, I did not realize that the formula from Excel would be exposed. Thanks!
    I did find the formula on Duponts site, however this site will not let me post the link to it until I get over 15 posts.
    Feb 2008
    Norway
    57
    446
    Quote Originally Posted by lwarren View Post
    You'd better start posting heavily
    Can you send the link to me directly?
    Split Croatia
    57
    6,151
    36
    Of course you could!
    Write like this: smmn://zzz.refrigeration-engeineer.com
    Mar 2008
    Ok, here it is:
    abbc://yyy.refrigerants.dupont.com/Suva/en_US/pdf/h16419.pdf
    This is actually the formula for pressure from temperature, which is what I asked for. However, I actually need to convert pressure back to temp so I will have to try to figure out how to redo the formula.
    Split Croatia
    57
    6,151
    36
    I think that any high school pupil good in mathematics can do that for you easy. Al relationships and constants are there, and it should be easy to derive formula for temperature.
    Feb 2008
    Norway
    57
    446
    Can you do it?
    Oct 2005
    In a 2 bedroom unit. Why's That? :)
    314
    Thumbs up Re: R22 Temp To Pressure Formula
    Hi.
    Where I use to work we used a program called MSR32.
    We connected 2 pressure transducers and had a ability to run 38 thermocouples through 2 data loggers. There is a formula but I neglected to write any down. Our visiting
    engineer wrote them into the program.
    So sorry mate. Give Solkane in germany a call. One of there engineers could help.
    Mar 2008
    My math is pretty rusty, but Im sure I can eventually figure it out. If I get it figured out I will post it, but if someone beats me to it please post the formula.
    Hey SteinarN, I found the formula, why don't you figure out how to reverse it for temp? LOL!
    Split Croatia
    57
    6,151
    36
    Can you do it?
    Yes, I can, but I will keep it for my self.
    Feb 2008
    Norway
    57
    446
    Dont laugh out to loud! Maby i do reverse it
  19. #19
    Aug 2005
    5,302
    Instead of rewriting the equation why not use a loop in the program? Use the pressure as an input and continue the loop until the temperature is within 0.001 of the results.
  20. #20
    Feb 2008
    Norway
    57
    446
    I had a 15 min look at the formula. It is slightly over my head to revrite it. Came to the same conclusion of a loop. But i will have a look at the excell option also.
  21. #21
    Aug 2005
    5,302
    It has been some time since I have looked at curve fitting the pressure to temperature. I seem to remember the accuracy was not too good, but then... how good would you need it to be?
  22. #22
    Feb 2008
    Norway
    57
    446
    The temperature to pressure formula from Du Pont has an average deviation of 0,11%. I would be happy if i got +-0,5C in deviation. I'ts just for information, not a part of the regulation of the heat pump.
  23. #23
    Split Croatia
    57
    6,151
    36
    I send this formula to my cousin who is doctor of mathematic science and professor of mathematic at Zagreb university. I expect his answer in few days.
  24. #24
    Aug 2005
    5,302
    I would be happy if i got +-0,5C in deviation. I'ts just for information...
    Then you may be satisfied with the Excel results. It has been some time since I did this, so you might want to check it yourself.
  25. #25
    Nov 2006
    63
    392
    which of the formulas in the document do you want reversing as I will see what I can sort out?
    Ian
  26. #26
    Aug 2005
    5,302
    Ian,
    The equation he is looking for is reverse of the temperature to pressure equation with all of the log base 10 fun stuff.
    They are trying to get the saturation temperature from the pressure.
  27. #27
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Pooh View Post
    Ian
    This is formula!
  28. #28
    Feb 2008
    Norway
    57
    446
    This is formula!
    We are looking for a formula which begins like this: T=???
    "T" is the temperature and is the value we want to find.
    "Psat" is the saturated pressure this formula will calculate when "T" is known.
    We know "Psat" and want to calculate "T".
  29. #29
    Split Croatia
    57
    6,151
    36
    I am aware of that! Look at post 20.
  30. #30
    Feb 2008
    Norway
    57
    446
    Hmmm, cant find post 20 to be relevant to your post 29.
    A only tried to be helpfull.
  31. #31
    Split Croatia
    57
    6,151
    36
    Yes I am aware, but you quoting me and replying to me!
    And I knew what we (in fact Iwarren) want from this formula ( picture in my post no.27) and I said, that I send that formula to my cousin (post 23) to derive what you stated in post 28
    What a mess.
    I see now, you looking in linear mode and I looking in hybrid mode.
    Correcting this mess....
    Corrected!
  32. #32
    Aug 2005
    5,302
    You guys just found one of the interesting features of this forum. I typically use the last post first view so I can read the most current post first.
    When someone refers to a post use the post number, not by relative location or we will have a big mess!!!
  33. #33
    Mar 2008
    Thanks nike123, I was not looking forward to trying to figure that out. I appreciate the help from everyone here.
  34. #34
    Mar 2008
    This also has me confused; if you look at the Units and Factors for that equation it says that
    T = temperature in deg. R = deg. F + 459.69 deg.
  35. #35
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi all
    maybe to see this:
    http://www.fchart.com/ees.shtml#1.1
    http://www.fchart.com/eesdemo.shtml
    http://www.fchart.com/eesexmpl.shtml
    hope this is of some help
    Best regards, Josip
  36. #36
    Aug 2005
    5,302
    When you are doing gas law or thermodynamic calculations you have to use absolute pressure and temperature.
    This means your pressure transducer has to be absolute pressure (which you use in the equation) and then subtract 14.69 psi from it for gauge pressure (unless you are in a vacuum) for the display.
    The same thing applies to temperature. You have to add 459.69 to your temperature readings then plug it into the equation (or subtract depending on what you are doing).
    And you thought this was going to be easy???
  37. #37
    Aug 2005
    5,302
    Hi Josip,
    EES is what I use for most information and calculations. It is a very good program, but a little expensive.
  38. #38
    Mar 2008
    Hey nike123, did your cousin ever figure out how re work that formula for temperature?
  39. #39
    Split Croatia
    57
    6,151
    36
    He didn't answered yet!
    I will remind him in few days. These successful youngsters today are pretty unorganized.
  40. #40
    Mar 2008
    No problem, I appreciate your help.
  41. #41
    Split Croatia
    57
    6,151
    36
    Today I have conversation with my cousin and only he could came up with this problem is that he and his colleagues cannot derive formula from this one, and he advise me to take approach with Excel as one with most likely useful for your goal.
    He told me that he will try to came up with some useful solution in near future and that he will discuss this problem with his colleagues.
    I will keep you posted with development on this mater.
    It seems that you make some shock in mathematical community.
  42. #42
    Jun 2006
    Arizona
    Are you searching for a computer program that has the ability to convert R22 temperature to pressure correlation? If so I have it. We can convert this in F to PSIG or in C to KPA. Operates on Windows based computers with Windows .net Framework 2.0 as pre-requisite operating system. We can also convert this same calculation for 28 other Refrigerants. For blends we output both Dew Point and Bubble Point readouts.
  43. #43
    Feb 2008
    Norway
    57
    446
    I'm searching for a formula to incorporate in a PLC program for conversion from pressure to temperature. Do you have such a formula mcjo tech?
  44. #44
    Jun 2006
    Arizona
    StienerN
    If you could please explain your application and applications needs it would help me to understand what it is you may require. Is it the formula you require? Our software does not have a basic formula. Or is it just a program that is capable of these correlations? If it is something that there would be a demand for I am sure we could produce some custom software for this application.
    Joe
    ExactCharge Industries,Inc.
  45. #45
    Feb 2008
    Norway
    57
    446
    I've made a large heat pump controlled by a PLC with a HMI panel conected. It is installed HP and LP tranducers conected to the PLC, so it is possible to read out the pressures. But I would like it to be possible to read out the condensing and evaporator temperatures also. Thats the reason I need the formula to convert from pressures to temperatures, a formula which can be incorporated in the existing PLC program.
  46. #46
    Jun 2006
    Arizona
    Thanks,
    I understand you application now. Our software for Pressure/Temperature correlations is not formula based but rather logic based so we would not be able to help in your application. I am sure that there is a formula which can accomplish your needs but we do the correlations by different means. Sorry we could not be of more help.
  47. #47
    Jan 2006
    Croatia
    68
    2,261
    31
    I believe that formula is not simple, having 4 non linear basic formulas to calculate properties charts.... in other hand if its so why to loose the time to make charts .... just give few formulas and we can calculate what we need
    ..... when you read those articles with so many equations, interpolations....information
    http://www.imst-art.com/ficherosdesc/interpolation.pdf
    http://nii.nist.gov/srd/REFPROP7doc1.pdf (1.69MB)
    http://potomac.nist.gov/srd/PDFfiles/REFPROP8.PDF
    ..... agree with you, after reading above articles I understood why EES are so expensive a lot of efforts.... but definitely worth that money....
    .....It is installed HP and LP tranducers conected to the PLC, so it is possible to read out the pressures. But I would like it to be possible to read out the condensing and evaporator temperatures also.
    .... why not use those pressures and in the same row show adjacent temperature for that pressure according to charts... then install another two temperature probes and make possible to read suction and discharge superheat what is more important ....
    .... seems we cannot help much...when you read above articles I believe you will realize why, but still you can use the same way....
    ..... seems using properties charts and normal programing procedures is inevitable process
    .... of course I can be wrong.... just my 2pence
    Best regards, Josip
  48. #48
    Split Croatia
    57
    6,151
    36
    I downloaded software Wolframs Mathematica today and I am going to install it, and try to came up with something.
  49. #49
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, nike123
    what to say.... good luck
    maybe to use one of those ... close to CoolPack
    http://www.et.web.mek.dtu.dk/WinDali...nDali_2.10.ZIP
    http://www.et.web.mek.dtu.dk/WinDali/Files/WinDali.pdf
    http://www.et.web.mek.dtu.dk/WinDali...fEqns_3.10.ZIP
    all above is here...
    http://www.et.web.mek.dtu.dk/WinDali/Index.html
    Best regards, Josip
  50. #50
    Aug 2005
    5,302
    Well it seems everyone is insisting on doing this the hard way. Try this...
    Temp=-8.13681513E+01+3.20065359E+00*Press-3.81813098E-02*Press^2+2.96408154E-04*Press^3-1.29284314E-06*Press^4+2.90447694E-09*Press^5-2.61193736E-12*Press^6
    Temp = °F (saturation temperature)
    Press = psia (valid for range of 10 psia to 315 psia)
    It may not be exact to 4 decimal places but it should be close enough.
    Edit: this applies to R-22 only!!
  1. Compressor loading, cooling, and range of operation.
  2. Benji
  3. Replies: 0
    Last Post: 28-08-2007, 09:48 AM
  4. Building a wine cabinet
