Results 1 to 29 of 29
Thread: R22 replacement
22-04-2008, 11:07 AM #1
R22 replacement
I am working on a project to Replace R22 in multiple medium and low temperature evaporators in a commercial enviroment. After much research i have found that no-one seems to have any distinct answers to this quirey. The nearist i have come to a replacement is R417A, however it seems this is used mainly for a/c systems. Could this possibly be used as a sutiable replacement and if not could anyone surgest any others? I would greatly appreciate some feedback. Thank you
Bradley SD
BJA trainiee Refrigeration design engineer
22-04-2008, 11:52 AM #2
Re: R22 replacement
r507, if the compressors are hermetic and have mineral oil it could be a pain to retrofit though.
Nearly every system made in the last 4 years here for med and low temp has been 404a or 507Last edited by paul_h; 22-04-2008 at 11:55 AM.
22-04-2008, 01:53 PM #3
Re: R22 replacement
R434a(RS45)
Looks good
http://www.refsols.com/RS-45.htmlIf it ain't broke, it doesn't have enough features yet.
Damo
22-04-2008, 02:34 PM #4
Re: R22 replacement
I'm looking at using R-507 as a replacement for R-22 on a similar project. It looks like it will have some issues as paul_h also mentioned, but I believe these are not insurmountable.
I would also rather use an azeotrope to eliminate the glide temperatures and fractionation issues.If all else fails, ask for help.
22-04-2008, 04:02 PM #5
Re: R22 replacement
Ive ran R507a through microcalc and come up with some pretty convincing performance results . however the power usage is a little more then i bargend for and the extra superheat (%) is double that of R22 (mind you depends how much you trust an anyliser), iul compare to R434a and get back to ya. cheers iceman!
22-04-2008, 04:11 PM #6
Re: R22 replacement
The impact of the power might be reduced by using a slightly larger condenser. Yeah, I know it costs more initially but in the long run I suspect it will be more cost effective if you included all the time messing around with the zeotropes or other alternatives.
Keep us posted on your findings. You might find something useful for the rest of us.If all else fails, ask for help.
22-04-2008, 04:16 PM #7
Re: R22 replacement
good point, thanks, what did i do without this forum!
23-04-2008, 12:23 AM #8
23-04-2008, 09:43 AM #9
Re: R22 replacement
shhhh! i dont think the techie blokes caught on yet , And besides its office related.... honest, *shifty eyes*
The computer made me do it! :p
25-04-2008, 09:08 PM #10
Re: R22 replacement
Did anyone hear of the ISCEON Range of Du Pont.
We are testing it on a small R-22 pump system now.
No oilchange, no gasket change (allthough some broke) and no change in components.
Still running after 5 week now.
27-04-2008, 07:00 AM #11
Re: R22 replacement
i work on the supermarket refrigeration..we used R422d (mo29) to replace R22. check dupont website.
28-04-2008, 09:37 AM #12
28-04-2008, 11:55 AM #13
Re: R22 replacement
Hello Brad,
We are using MO29 (R422d) for the test.
It is a test with the customer and supplier and ourselfs to look for good and easy replacements for Pumpsystems with R-22.
This becuase you only know if it works when you try it.
We want to wait untill summer (hot hahaha)to make a good (or bad) report on the test but so far so good.
28-04-2008, 12:39 PM #14
Re: R22 replacement
Hey Bart, thanks for the feedback... Ive just had Mark Huges (sales manager for ISCEON) on the phone and hes told me all about the stuff ... case studies, tests in germany blah blah, relaible, blah, plentiful, you could say im sold...lol
thanks again
Bradley SDThe computer made me do it! :p
30-04-2008, 08:28 AM #15
Re: R22 replacement
drop in replacement for R22 i think is RS-44
01-05-2008, 10:51 PM #16
01-05-2008, 10:59 PM #17
20-05-2008, 06:40 PM #18
Re: R22 replacement
For information on R22 replacements visit gas2010.com
20-05-2008, 07:28 PM #19
Re: R22 replacement
Although the hydrocarbons are good refrigerants, I would not recommend them for normal public use.
We have a difficult time with using the refrigerants we have on the market without compounding the issue of flammability and other issues common to hydrocarbon refrigerants.If all else fails, ask for help.
15-06-2008, 03:34 AM #20
Re: R22 replacement
How about Mycoms. I have 2 FW6 Receipts with water cooled heads. My head pressure runs around 175 with the tower...At the end of the year I will need to switch refrigerants..On Mycoms what do you think about Refrigerants
11-07-2008, 03:28 AM #21
Re: R22 replacement
Look Here Friends;
There are 3 choices in this family for your consider
R417a composition is
R125, R134a, R600
46.6%, 50%, 3.4%
design for household air-con
R422d composition is
R125, R134a, R600a
65.1%, 31.5%, 3.4%
design for household air-con, refrigeration
R422a composition is
R125, R134a, R600a
85.1%, 11.5%, 3.4%
design for refrigeration, chiller
More R125 more capacity
More R134a more COP
R600 & R600a the reason why no oil change its made compatible between HFC to Mineral oil.
We will be back, friends
Mr.Blue
21-07-2008, 10:15 AM #22
Re: R22 replacement
Hey guys
This is Rohit, do anybody have comparison of R22 and R404A system design and performance>
Pls let me know
09-09-2008, 10:17 PM #23
Re: R22 replacement
Hi Iceman,Brad 34
Have you got some good results on your research on R434a?
If all these people on the forum are very experienced, i can't understand that R434a is not looked at more...
To me it seems one of the best replacements for R22 at this moment.
I really like to here all your expertise on this matter. Because I might be using it to retrofit a DX glycol chiller
30-04-2010, 08:04 AM #24
11-05-2010, 09:48 AM #25
Re: R22 replacement
Dupont's MO99 does not need an oil change and it works pretty good in medium temp applications and a/c
29-05-2010, 07:38 PM #26
Re: R22 replacement
MO29 works ok but tends to cause lots of leaks due to shrinking or drying up o rings and gaskets ..... we have learnt the hard way and it has cost us alot of money to go round swapping these things to resolve the issues
04-06-2010, 02:58 PM #27
Re: R22 replacement
depending on your operating conditions you could lose up to 28% capacity on low temp and roughly 20 percent on medium temperature with 417A. if you have that much excess capacity. it should work but i would be cautious with oil return using mineral oil, if you have good oil seperators and short piping runs and no receiver it should work, if not you will see oil in the receiver and must start adding POE oil to get good return. better path is to use an HFC with better capacity and switch to synthetic lube. hope this helps.
04-06-2010, 03:13 PM #28
Re: R22 replacement
Sure will work better than 417 from a capacity perspective, i think my comments about oil return with 417 would still hold true with this blend as well. you need to check the oil return and add poe if it is slow. DuPonts and copelands application bulletins indicate this.
04-06-2010, 09:06 PM #29
Re: R22 replacement
Hi there
I am droping in R422D in plants until 400 kgs of refrigerant.
No problems at all.
I am very impressed about.
R 417 A direct replacement of R 22
By abbasi in forum RefrigerantsReplies: 28Last Post: 08-09-2011, 12:47 AM -
new r22 drop-in replacement
By nh3simman in forum RefrigerantsReplies: 46Last Post: 04-06-2010, 07:44 PM -
HFC Replacement for r22 in flooded system
By kevinM in forum RefrigerantsReplies: 8Last Post: 26-03-2008, 02:02 PM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
