    Aug 2005
    uk
    Hotpoint Fridge Freezer
    Is anyone can give me electrical diagram of Hotpoint fridge freezer model FFA74.My problem is the evaporator fan motor is not working.When i test the terminal going to efm, has no voltage,Only the fridge is getcooling, im not satisfied also because the condenser is cold.i found also there is solenoid after filter drier,when icheck it,it has no voltage.could you give me idea.im very far now in refrigeration,
    Thanks,
    Cesar
    Re: Hotpoint Fridge Freezer
    Hi Cesar, in the absence of any answers from here try http://www.ukwhitegoods.co.uk/
    Aug 2005
    uk
    thanks brian to that site you gave me,its helpul but theres no answer in my question,anyway i apprecite it
    Many thanks,
    Cesar
    Oct 2004
    Scotland
    1,454
    Hi C Bagtas,
    Use the search function of this site and you will come up with many answers...
    http://www.refrigeration-engineer.co...earchid=322833
    Chillin
    and go get a cuppa
    dino2020's Avatar
    dino2020 Guest
    Hi, I am having the same problem the fan will only spin for a few seconds after the power is restored if left off for a while, The top of the freezer is maybe 0c and the bottom gets down to maybe -5c. The fridge seems to be at an ok temp though there does seem to be a bit of water collecting under salad draws. The link above doesnt seem to work and I am not really sure what I am looking for with the search function, Can you point me to the right thread.
    To add I took the back panel off and it was not iced up, I also got a multimeter and there is no power been sent to the fan other than for the few seconds when power is restored.
    Jul 2006
    norfolk
    737
    need to replace the pcb on the unit and it will sort the problem out
    dino2020's Avatar
    dino2020 Guest
    Is there a specific fault on the pcb as I have a friend who is an electronics engineer and I am sure he would be able to repair it. I am sure he could trace it, but if some one knows what the problem is, I am sure he would appriciate it
    So not a thermosat/thermistor problem then?? nothing that cheap Unit is only just over 12 months old, and reading on the net that some people had 3 PCB's in 3 years
    Jul 2006
    norfolk
    737
    Hotpoint have 5 years warranty on all there appliances but you will have to pay the £90 call out,which is cheaper than a new fridge/freezer
  1. Replies: 18
    Last Post: 13-06-2011, 11:49 PM
  2. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  3. Replies: 6
    Last Post: 25-10-2010, 01:25 PM
  4. fridge freezer cooling fan
    By bazza in forum Trouble Shooting
    Last Post: 28-02-2007, 11:33 PM
  5. Help! fridge freezer probs
    By Glenreed in forum Trouble Shooting
    Last Post: 06-01-2006, 10:51 PM
