Results 1 to 28 of 28
Thread: Annie A-12 hermetic compr tester
11-11-2004, 07:11 PM #1
Has someone the manual for a vintage Annie A-12 hermetic compressor tester?
I bought this unit 2nd hand 15 years ago and lost the manual.
There are 4 leads: white, yellow, black, red. 3 indicators.
Peter.
11-11-2004, 07:29 PM #2
Re: Annie A-12 hermetic compr tester
Hi peter
I remember making a simple version of annie for testing compressors ...........................?
I believe my old work buddy still has a annie in his garage,i will call round when i get time and check it out .If thats any help.
Mark
11-11-2004, 09:05 PM #3
Thanks Mark. Any help is welcome.
It's of course possible to make one myself but this is a handy unit with different capacitors, reverse run, ohm, AMPS , Volts indication,...
Peter.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
14-11-2004, 07:19 PM #4
Hope this helps
14-11-2004, 08:57 PM #5
Mark,
If you were a girl, then I should give you a kiss
Thanks, thanks, thanks...
This forum and teh help from others is great.
Just had a quick look, what is the meaning of the transformers?
PeterLast edited by Peter_1; 14-11-2004 at 08:59 PM.
14-11-2004, 10:44 PM #6
T2 is the transformer for the HI LOW range of the AMP meter M2
S2 is the switch RELAY/OFF/LINE.
Meaning of Transformer T1?
The resistor R? (can't read it) right on top is for the 0 adjustment of M1 (ohms)
Before each neon light (110 VAC) an in line resistance to divide the 220 VAC voltage.
S6 pushbutton START CAPACITY
S5 selector for different start capactities
S3 MASTER SWITCH ON/OFF /REVERSE.
S4 is switch POWER/RELAY/OHMS.
What is the meaning of R8 variable potmeter?
4 leads ..purpose?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
14-11-2004, 11:23 PM #7
when used to start and run a comp
red --run
black --comon
white --start
yellow is unused in this test but make sure you cover it up because if it touches the caseing it will spark, blow the fuse and you will get a frightIF AT FIRST YOU DON`T SUCCEED.
and go get a cuppa
15-11-2004, 06:45 AM #8
So, what is the meaning then of the yellow wire? Starting with cap's?
15-11-2004, 07:32 AM #9
Mark,
Sorry I have to ask but wasn't there some sort of manual with it?
PeterIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
15-11-2004, 08:41 PM #10
Hi Peter
Im in the progress of obtaining a paper copy,once i recieve it
you can have a copy.
Mark
15-11-2004, 08:57 PM #11
no it`s used to test a capacitor
(black and yellow)
and also i think you can use it as an insulation tester
the capacitors are built in and you can`t not start a comp without using one thats why it`s good for freeing stuck ones.
put it on the highest capacitor and rock it (forward then reverse) and at the same time boot the comp.
used to work for me and if it didn`t ....... well it was knacked anyway.
and go get a cuppa
14-05-2005, 10:35 PM #12
Hi Everyone;
I have been trying for years to obtain a manual for this tester. If anyone has one I would love to have a copy. I have the 1 to 3 phase model, A-12.
Any help appreciated, pleaase reply to: jimott@charter.net Thanks
15-05-2005, 09:11 AM #13
Posted by Mark Fiddy
http://www.refrigeration-engineer.co...ead.php?t=2138It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
30-07-2005, 03:32 PM #14
I have this manual saved in a file if anyone needs it. My e-mail is briancfurman@msn.com
20-03-2006, 01:47 PM #15
Could you possibly scan pictures of the actual manual pages for me mark?
Derek
21-03-2006, 07:05 AM #16
If you need a copy send me message , with your mail address
Jim Ott
B1ack LotusThe primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
15-07-2007, 10:57 PM #17
did anyone find a instruction manuel for annie?
15-07-2007, 11:04 PM #18
Raceman710@aol.com... thank a bunch.......
16-07-2007, 05:34 AM #19
Raceman710, nice intro you made here, welcome I should say. Seemed the door was open?
This question is made the last years at least 5 times.
It all can be found on this forum. Just make a search and there it is.
The link is even givenIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
24-07-2007, 03:12 AM #20
I have this manual in pdf format if you still need it. Just email me at briancfurman@msn.com
11-12-2007, 03:32 PM #21
i need the annie analyzer instructions book
please send to doug@papermoneyworld.net
17-12-2007, 10:01 PM #22
I just bought one on Ebay for 36.50 plus 15 bucks freight. it came in Saturday. There was a wire off the terminal of one of the caps.
17-09-2008, 10:25 PM #23
I don't spose anyone has a copy of the ANNIE A-12 D operating manual???
HELP...
17-09-2008, 10:26 PM #24
dude you got a copy for the A12-d?
18-09-2008, 06:09 AM #25
If Dude should use once the search button in this forum, you should find what you're looking for.
18-09-2008, 02:42 PM #26
send me your email I have it in pdf file.
08-11-2008, 10:19 AM #27
I still can't find what I am looking for.. The unit is a Imperial Eastman A-12D with LCD display not the analouge unit.
Even Johnson Controls don't have a copy..
Any way, my unit is tripping the rcd when I try to use the 240 volt test and I'm not an electronics engineer so I can't quite work out what I need to replace.
30-04-2010, 02:50 PM #28
Re: Annie A-20 hermetic compr tester
I need information on Gould A-20
do we need a hermetic or semi hermetic comp.?
By duraid in forum FundamentalsReplies: 14Last Post: 17-04-2007, 05:52 PM -
Hermetic reciprocating versus hermetic scroll
By Cofreth in forum Technical DiscussionsReplies: 26Last Post: 19-11-2005, 06:29 PM -
Hermetic analyzer
By Mickvee in forum Tools and CalculatorsReplies: 2Last Post: 16-04-2005, 10:20 AM -
Good old annie
By Cary in forum Tools and CalculatorsReplies: 7Last Post: 27-03-2005, 10:25 PM
