    Dec 2012
    Australia
    9
    Compressor Windings
    I have a 22 kW Mitsubishi Electric condensing unit with a 10HP Mitsubishi compressor that comes up with U6 error code. A U6 error code is over current.
    The compressor is a 3 phase compressor with a maximum running current of 22 Amps.
    I test the compressor for the following:
    Phase to phase resistance of all windings is 17 Ohms
    Insulation resistance of all windings is 0 Megohms.
    The compressor runs for about 1.0 to 1.5 seconds then comes up with the U6 error code.
    Does any one know what the compressor winding should be for a Mitsubishi Electric compressor model # JH521YEB?
    I have been told around the 1.0 Ohm or so.
    If the compressor windings have increased in resistance, how is this so?
    After talking to Mitsubishi I have found that a U6 error occurs from one of 2 inputs:
    The thermal overload NC contacts or the compressor thermostat, NC contacts which are in series.
    I have disconnected both of these and bridged the CN23 pins on the outdoor circuit board and the outdoor unit comes up with a H7 code then trips the circuit breaker when started.
    I have tested the contactor - Perfect
    I have tested the the thermal overload - Perfect
    I plugged in CN23 connector after this test and I get H2 & H6 code.
    As the compressor is not down to earth or not jammed, can anyone of you giys come up with what is going on?
    This one is a first for me, 40 years of doing this!
    Oct 2001
    Nottingham UK
    5,667
    Re: Compressor Windings
    Quote Originally Posted by petem View Post
    Winding resistance to Ground (Earth) should be very high when measured using a Meggerohm meter.
    A reading of 0 Megohms indicates a direct short
    Dec 2012
    Australia
    9
    Sorry, I wrote that down wrong, resistance is high, no leakage to earth
    Oct 2001
    Nottingham UK
    5,667
    If you disconnect the compressor from the circuit does the unit still trip on overcurrent?
    Dec 2012
    Australia
    9
    No,
    As I said, the windings are not down to earth using a megger at 1000V and resistance between all three windings is 17 ohms.
