Results 1 to 19 of 19
05-06-2006, 08:21 PM #1
Re: how to test the superheat setting value of a thermo expansion valve?
You can check the setting on the orifice cage if it is a TEV made up from body and power head.
Otherwise you will have to test it when the system is operating.
Tricky name you have, it doesn't run easily off the tongueBrian - Newton Abbot, Devon, UK
05-06-2006, 08:58 PM #2
What brand is it?
TEV superheat setting and low temperatures
By DaBit in forum FundamentalsReplies: 11Last Post: 01-03-2010, 02:11 AM -
Fitting an expansion valve question
By Larry2 in forum Air ConditioningReplies: 20Last Post: 08-04-2008, 04:17 PM -
expansion valve aint cold
By justinworne in forum Trouble ShootingReplies: 6Last Post: 26-07-2006, 10:52 PM -
I want to find detailed files about ALCO zz thermo expansion valve
By brightfu1 in forum FundamentalsReplies: 2Last Post: 07-09-2005, 03:07 PM -
Oversizing EXV electronic expansion valve
By aygul in forum Technical DiscussionsReplies: 5Last Post: 20-11-2003, 01:00 PM
