    Jul 2017
    Qatar
    38
    3
    Pressure drop at condenser
    Hi friends,
    At Evapco documents regarding condensers I read that when a condenser works it has pressure drop during pipes and while it is idle , It has not any pressure drop and pressure of inlet would be same with pressure of outlet.
    Would it be possible someone make it clear for me, Why when condenser does not work it has not pressure drop ?
    Please see photo at below
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    439
    26
    Re: Pressure drop at condenser
    Friction pressure losses and changes in saturation temperature in the dynamic system (operating condenser)
    Sep 2010
    70
    209
    11
    Pressure drop is due to friction losses along the pipe length when the fluid is moving along the pipe.
    When the flow stops the friction loss also stops leaving just the static pressure which is equal throughout the system.
    Brian, retired in Devon.
    Sep 2008
    Canada
    781
    13
    We have pressure drop when someting (vapour, liquid) moving inside the pipe. Nothing is moving inside of idle condenser.
